Hemi Parts Question #2201294
11/23/16 04:54 PM
11/23/16 04:54 PM
Fort Lauderdale, FL
Suregrip Offline OP
Suregrip  Offline OP
Fort Lauderdale, FL
Okay here is a GEN 2 Hemi question;
I am installing a 426 Hemi into my 1971 Challenger in place of the 440. I want to use an NASCAR aluminum (or magnesium) factory single four barrel intake in place of the Hemi factory dual four set-up.
Will the single four barrel intake and carb line up with the hole for the Shaker hood, and will the height be close to say a stock 383 or 440 four barrel Shaker set up? Or am I stuck with using the factory dual four set-up?
Anyone done this before?
Some people you just can't reach...
Re: Hemi Parts Question [Re: Suregrip] #2201435
11/23/16 09:37 PM
11/23/16 09:37 PM
Fort Lauderdale, FL
Suregrip Offline OP
Suregrip  Offline OP
Fort Lauderdale, FL
Anybody?
Re: Hemi Parts Question [Re: Suregrip] #2201446
11/23/16 09:50 PM
11/23/16 09:50 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I officially have no clue but can't see the NASCAR piece sharing the same carb height. I imagine it'll be a bit taller.
- Stu Harmon
Re: Hemi Parts Question [Re: Suregrip] #2201448
11/23/16 09:51 PM
11/23/16 09:51 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I don't know if it will work or not, but you are likely to need to fabricate the base plate. I had a -3 Indy intake and Dominator on a RB under my Shaker. Had to drop the K and basically build a base plate and filter lid, but it worked good.
I now have an Indy DP and Dominator on my Hemi under the Shaker. So most anything can be done with a little (or lot of) fabrication.
Master, again and still
Re: Hemi Parts Question [Re: DaveRS23] #2201579
11/24/16 12:50 AM
11/24/16 12:50 AM
Fort Lauderdale, FL
Suregrip Offline OP
Suregrip  Offline OP
Fort Lauderdale, FL
Yes, I was thinking maybe the location of the single 4bbl carb would be centered on the 426 as it would be on the 440, as they are both RB blocks and share the same basic dimensions. The height could be an issue though, but may be easier to address...
Beuler? Beuler? Beuler?
Re: Hemi Parts Question [Re: Suregrip] #2201593
11/24/16 01:02 AM
11/24/16 01:02 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Get ahold of Jim V, hemi71x on this site. He has intakes for sale and might measure the heights for you.
