I don't know if it will work or not, but you are likely to need to fabricate the base plate. I had a -3 Indy intake and Dominator on a RB under my Shaker. Had to drop the K and basically build a base plate and filter lid, but it worked good.
I now have an Indy DP and Dominator on my Hemi under the Shaker. So most anything can be done with a little (or lot of) fabrication.
Master, again and still
