Hemi Parts Question
#2201294
11/23/16 04:54 PM
11/23/16 04:54 PM
Posts: 473 Fort Lauderdale, FL
Suregrip
Fort Lauderdale, FL
Okay here is a GEN 2 Hemi question;
I am installing a 426 Hemi into my 1971 Challenger in place of the 440. I want to use an NASCAR aluminum (or magnesium) factory single four barrel intake in place of the Hemi factory dual four set-up.
Will the single four barrel intake and carb line up with the hole for the Shaker hood, and will the height be close to say a stock 383 or 440 four barrel Shaker set up? Or am I stuck with using the factory dual four set-up?
Anyone done this before?
Some people you just can't reach...
Re: Hemi Parts Question
[Re: Suregrip]
#2201446
11/23/16 09:50 PM
11/23/16 09:50 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I officially have no clue but can't see the NASCAR piece sharing the same carb height. I imagine it'll be a bit taller.
[Re: Suregrip]
#2201448
11/23/16 09:51 PM
11/23/16 09:51 PM
Posts: 12,087 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I don't know if it will work or not, but you are likely to need to fabricate the base plate. I had a -3 Indy intake and Dominator on a RB under my Shaker. Had to drop the K and basically build a base plate and filter lid, but it worked good.
I now have an Indy DP and Dominator on my Hemi under the Shaker. So most anything can be done with a little (or lot of) fabrication.
Master, again and still
[Re: DaveRS23]
#2201579
11/24/16 12:50 AM
11/24/16 12:50 AM
Suregrip
Fort Lauderdale, FL
Yes, I was thinking maybe the location of the single 4bbl carb would be centered on the 426 as it would be on the 440, as they are both RB blocks and share the same basic dimensions. The height could be an issue though, but may be easier to address...
Beuler? Beuler? Beuler?
