is it worth it to carb a 6.4 #2192200
11/08/16 03:11 PM
11/08/16 03:11 PM
Tulsa
dubs chops Offline OP
Tulsa
I have a 6.4 longblock I am thinking of using as a project.
It doesn't come with the manifold or any computer. Would this be a candidate for a carb? I havent found much in the way of info on 6.4 carb swaps. I would eventually switch back to an EFI setup but for simplicity would like to grab the motor and throw a carb on it and go.
Re: is it worth it to carb a 6.4 [Re: dubs chops] #2192229
11/08/16 03:51 PM
11/08/16 03:51 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Would need VVT locked out,then carb away. If it's an auto version, it will need half the lifters swapped to non mds versions to iirc.
Mopar to the bone!!!
Re: is it worth it to carb a 6.4 [Re: dubs chops] #2192248
11/08/16 04:25 PM
11/08/16 04:25 PM
USA
hudsonhornet7x Offline
USA
72 Swinger is right, It can be done:
Use a comp cams lock out kit for the VVT
MDS lifters replaced with regular lifters
If using the MSD Hemi 6 ignition, you MUST change the tone ring on the crank to the older ring found on 6.1 hemis, as well as aftermarket stroker kits. Molnar Technologies sells the tone rings. You MAY need to change the crank sensor as well to read the different tone ring.
Install your favorite carb manifold and carb.
I will say that most folks that have spent the $$$ for a 6.4 also go with fuel injection, right or wrong. That is why most 6.4 builds are injected.
Hope this helps!
Re: is it worth it to carb a 6.4 [Re: dubs chops] #2192351
11/08/16 08:05 PM
11/08/16 08:05 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
For probably less than 1700.00 you can get the new stand alone from Fiat.
Comes with all sensors. There's a thread on here describing it.
Simplest and cheapest way IMO.
One thing is the donor engine needs to be 2014 or newer.
I think they changed the toner AKA reluctor wheel.
Matt
Re: is it worth it to carb a 6.4 [Re: dubs chops] #2192572
11/09/16 01:08 AM
11/09/16 01:08 AM
ghinmi Offline
ghinmi  Offline
You're going to spend more time goofing around trying to run it with a carb than you would getting the efi working. Just do the efi the first time since you already said that's the direction you'll eventually head.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street.
9.97 @ 140 slicks, 10.74 in autox trim
Re: is it worth it to carb a 6.4 [Re: MattW] #2194085
11/10/16 05:27 PM
11/10/16 05:27 PM
Tulsa
Tulsa
Matt
can you tell me more about this?
Re: is it worth it to carb a 6.4 [Re: dubs chops] #2194090
11/10/16 05:35 PM
11/10/16 05:35 PM
Tulsa
Tulsa
Re: is it worth it to carb a 6.4 [Re: dubs chops] #2194095
11/10/16 05:38 PM
11/10/16 05:38 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
If you're going to leave it stock, I would use the new Mopar standalone.
Re: is it worth it to carb a 6.4 [Re: 72Swinger] #2194128
11/10/16 06:11 PM
11/10/16 06:11 PM
Tulsa
Tulsa
do you have a link?
Re: is it worth it to carb a 6.4 [Re: dubs chops] #2194143
11/10/16 06:46 PM
11/10/16 06:46 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Look for spring for a release, but coming from Mopar it might be spring of 2019. I have the EFISource on my 6.1. Its great, call Mike right now since hes an hour later in PA.
Re: is it worth it to carb a 6.4 [Re: dubs chops] #2194155
11/10/16 06:58 PM
11/10/16 06:58 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Originally Posted By dubs chops
do you have a link?
https://board.moparts.org/ubbthreads/ubbt...tml#Post2188221
Re: is it worth it to carb a 6.4 [Re: dubs chops] #2194207
11/10/16 08:32 PM
11/10/16 08:32 PM
Tulsa
Tulsa
it says it is for 2014 and newer. Think the toner ring is the only difference?
Re: is it worth it to carb a 6.4 [Re: dubs chops] #2194857
11/11/16 05:28 PM
11/11/16 05:28 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
That's the post I was referring to.
Call Mopar performance and see what they say about the kits.
Matt
Re: is it worth it to carb a 6.4 [Re: MattW] #2202382
11/25/16 03:15 PM
11/25/16 03:15 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
call hotwire auto for more options
Re: is it worth it to carb a 6.4 [Re: 72Swinger] #2202495
11/25/16 06:46 PM
11/25/16 06:46 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Why?
What does it do for more than this?
http://www.efisource.com/shop/ms3-gen3-hemi-plug-play-gold-box/
Nothing, in fact it costs more to do it because you cannot tune it without additional, extra costs.
Unless you need a smog legal setup then the MP kit is an expensive choice.
Don't be the exception.
Re: is it worth it to carb a 6.4 [Re: Supercuda] #2202630
11/25/16 10:41 PM
11/25/16 10:41 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Why?
Because it uses the factory knock control,DBW throttle body and would need 0 tuning since it's already for a stock 6.4. By using the the stock TB that saves $300+ alone.
Re: is it worth it to carb a 6.4 [Re: dubs chops] #2202829
11/26/16 01:47 PM
11/26/16 01:47 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Did you go an actually look at the information on the MS3?
Because most of your objections appear to be unfounded.
It comes with a base tune that is also self tuning.
It is plug and play and they have a 6.4 version.
It works with VVT and active intake.
It works with the knock sensors.
And there is no need to either pay for a tuner or someone to tune it either, Tuner Studio is free.
As for the DBW throttle body, I dunno it doesn't say.
So add in the price of a new TB, which woulds be easier to retrofit, imo, than the drive by wire setup, the pricing is similar with a lot more accessible ability in the MS3 included for the price.
Re: is it worth it to carb a 6.4 [Re: dubs chops] #2202864
11/26/16 03:36 PM
11/26/16 03:36 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I have an MS3 and it still doesnt have knock control ability. I know from experience that new Mopar deal on a STOCK 6.4 would be the bomb.
Re: is it worth it to carb a 6.4 [Re: dubs chops] #2217874
12/20/16 05:10 PM
12/20/16 05:10 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
Hey,
For those of us that Bracket Race weekly..........carburetors are needed to keep dialing predictable.
Based on what I see here...............is it still doable to get a 6.4 or 7.0 to run on a carb?
Mike
Re: is it worth it to carb a 6.4 [Re: SILVER67] #2218320
12/21/16 12:59 PM
12/21/16 12:59 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
For sure it is, use a Ritter or DragPack intake (fairly tall) and MSD makes a controller to use for carbs. sixpackgut and other guys on this site have went this method with good results. OU812 did a 6.4 build that was carb'ed and it did 700 hp (he posted his results in this subforum)
