Intake/Head Porting Epoxy #218979
02/09/09 05:24 PM
02/09/09 05:24 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
What do you guys use for epoxy to shape or fill in pin holes?
Have any of you used Lab Metal epoxy?
Re: Intake/Head Porting Epoxy [Re: Scamp408] #218980
02/09/09 06:39 PM
02/09/09 06:39 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I been using JB weld works fine!
Re: Intake/Head Porting Epoxy [Re: Dodgem] #218981
02/09/09 08:35 PM
02/09/09 08:35 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I was thinking JB but I was told it wont hold up.
Re: Intake/Head Porting Epoxy [Re: Scamp408] #218982
02/09/09 08:38 PM
02/09/09 08:38 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
MOROSO ..... A & B epoxy
1.39 9.85 - 137 mph
Re: Intake/Head Porting Epoxy [Re: Ari440] #218983
02/09/09 09:04 PM
02/09/09 09:04 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Re: Intake/Head Porting Epoxy [Re: Scamp408] #218984
02/09/09 09:09 PM
02/09/09 09:09 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
I just ordered some high temp Lab Metal from Eastwood. P.M. me in a couple days and I'll let you know what I think of it.
TR Waters
Re: Intake/Head Porting Epoxy [Re: Scamp408] #218985
02/09/09 09:59 PM
02/09/09 09:59 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
You have to tell my heads that 3 1/2 years and perfect vacuum tests on heads??
Re: Intake/Head Porting Epoxy [Re: Dodgem] #218986
02/09/09 10:59 PM
02/09/09 10:59 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Did you seal the port from a air leak or a water leak. And Im not implieing that there is anything wrong with JB weld. mike
Re: Intake/Head Porting Epoxy [Re: Sport440] #218987
02/09/09 11:01 PM
02/09/09 11:01 PM
houston texas
gremlinsteve Offline
houston texas
z-spar...but i think they stopped making it.
steve
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: Intake/Head Porting Epoxy [Re: gremlinsteve] #218988
02/09/09 11:12 PM
02/09/09 11:12 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
steve
WHAT?
JB Weld is OK for filling pinholes (to air) or rocker cover
bolt-holes but, it's too snotty for shaping, unless you dam
it up somehow and grind it to shape after it sets up.
Re: Intake/Head Porting Epoxy [Re: S/ST 3040] #218989
02/10/09 07:26 AM
02/10/09 07:26 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Re: Intake/Head Porting Epoxy [Re: Scamp408] #218990
02/10/09 01:43 PM
02/10/09 01:43 PM
houston texas
houston texas
z-spar is the company name.
splash zone is also a name its called.
part number is a-788
here is a small link to what i am speaking of. green when cured. do not breath the dust when grinding. we use it in the comp eliminator motors.
we do not use it on the exhaust side for obvious reasons.
http://www.go2marine.com/product.do?no=79357F
steve
Re: Intake/Head Porting Epoxy [Re: gremlinsteve] #218991
02/10/09 01:49 PM
02/10/09 01:49 PM
S/ST 3040 Offline
S/ST 3040  Offline
Re: Intake/Head Porting Epoxy [Re: S/ST 3040] #218992
02/10/09 01:57 PM
02/10/09 01:57 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
How does this stuff hold-up using an alky-blend fuel ?
Re: Intake/Head Porting Epoxy [Re: dOrk !] #218993
02/10/09 02:08 PM
02/10/09 02:08 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Goodson sells Z Spar splash zone under their house brand porting/reshaping kit. # PRK-99
I been using PC products croncrete epoxy alot lately, it's closest stuff I've seen to Belzona 1111 Super Metal yet, but with 1/15 the cost. I buy it in caulking gun tube for around $20. It's what I used in my W9RP heads to knock 20 CC of volume out.
Re: Intake/Head Porting Epoxy [Re: Sport440] #218994
02/10/09 04:04 PM
02/10/09 04:04 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Had air (oil would have gotten through) when I had the SR heads welded to turn them into 440-1's on the intake. We've always used JB even on my old iron heads seems to hold on forever.
Re: Intake/Head Porting Epoxy [Re: Dodgem] #218995
02/10/09 04:12 PM
02/10/09 04:12 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
The trick with JB weld is mix it and keep checking it till you get a form able paste. Of course sometimes you come back to a hard lump!
My machinist likes to apply outside and suck into porus spots with suck tester then coat over after.
