Re: Intake/Head Porting Epoxy
[Re: Scamp408]
#218984
02/09/09 09:09 PM
02/09/09 09:09 PM
Posts: 2,129 Vermont
TrWaters
Vermont
I just ordered some high temp Lab Metal from Eastwood. P.M. me in a couple days and I'll let you know what I think of it.
TR Waters
[Re: Scamp408]
#218985
02/09/09 09:59 PM
02/09/09 09:59 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
I was thinking JB but I was told it wont hold up.
You have to tell my heads that 3 1/2 years and perfect vacuum tests on heads??
[Re: Dodgem]
#218986
02/09/09 10:59 PM
02/09/09 10:59 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Did you seal the port from a air leak or a water leak. And Im not implieing that there is anything wrong with JB weld. mike
[Re: Sport440]
#218987
02/09/09 11:01 PM
02/09/09 11:01 PM
Posts: 1,828 houston texas
gremlinsteve
houston texas
z-spar...but i think they stopped making it.
steve
if You Like Gremlinsteve. Gremlinsteve Likes You.
[Re: gremlinsteve]
#218988
02/09/09 11:12 PM
02/09/09 11:12 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
steve
WHAT?
JB Weld is OK for filling pinholes (to air) or rocker cover bolt-holes but, it's too snotty for shaping, unless you dam it up somehow and grind it to shape after it sets up.
[Re: Scamp408]
#218990
02/10/09 01:43 PM
02/10/09 01:43 PM
gremlinsteve
houston texas
z-spar is the company name. splash zone is also a name its called. part number is a-788 here is a small link to what i am speaking of. green when cured. do not breath the dust when grinding. we use it in the comp eliminator motors. we do not use it on the exhaust side for obvious reasons. http://www.go2marine.com/product.do?no=79357Fsteve
