can someone school me on lash caps on a 426 hemi?
#218730
02/09/09 01:31 PM
02/09/09 01:31 PM
Posts: 8,846 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
never messed with any kind of lash caps whats the deal and how you do it? ralph
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: can someone school me on lash caps on a 426 hemi?
[Re: Mac's Hemi 64]
#218733
02/09/09 04:19 PM
02/09/09 04:19 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
595 310 roller 11-1 compression alum head street/strip
[Re: toplescuda]
#218734
02/09/09 04:29 PM
02/09/09 04:29 PM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
You have to use lash caps with a Hemi. It saves the valve tips and you need the extra surface area for the rollers. I use the Comp # 619 caps made for .308 valve stems. You have to use locks that are recessed for the caps. Use Comp # 610 locks (10 degree)
[Re: Mopar_Rich]
#218737
02/09/09 05:04 PM
02/09/09 05:04 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
It's not and absolute must,but as Mopar Rich says if you want to save your valve tip(5/16)then it is best to run them.We don't normally use them on the Indy Legends(11/32)stem unless we need added clearence or to adjust geometry.Make sure that the retainer,locks and lash caps are compatable there are a few different lengths and depths on the lash caps.
