can someone school me on lash caps on a 426 hemi? #218730
02/09/09 01:31 PM
02/09/09 01:31 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
never messed with any kind of lash caps whats the deal and how you do it?
ralph
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: can someone school me on lash caps on a 426 hemi? [Re: toplescuda] #218731
02/09/09 01:56 PM
02/09/09 01:56 PM
You need to have the retainers and lash caps designed to work with each other, the Hemi lash caps are real short usually also so I wouldn't try and run them on a loose lash cam. I know racers that did and the lash caps would come off frequently and cause problems
Re: can someone school me on lash caps on a 426 hemi? [Re: toplescuda] #218732
02/09/09 02:21 PM
02/09/09 02:21 PM
Joplin, Missouri
Mac's Hemi 64 Offline
Joplin, Missouri
What kind of setup race motor, street?
Re: can someone school me on lash caps on a 426 hemi? [Re: Mac's Hemi 64] #218733
02/09/09 04:19 PM
02/09/09 04:19 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
595 310 roller 11-1 compression alum head street/strip
1971 charger
Re: can someone school me on lash caps on a 426 hemi? [Re: toplescuda] #218734
02/09/09 04:29 PM
02/09/09 04:29 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
ralph
You have to use lash caps with a Hemi. It saves the valve tips and you need the extra surface area for the rollers. I use the Comp # 619 caps made for .308 valve stems. You have to use locks that are recessed for the caps. Use Comp # 610 locks (10 degree)
Re: can someone school me on lash caps on a 426 hemi? [Re: Mopar_Rich] #218735
02/09/09 04:31 PM
02/09/09 04:31 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Here's how the locks work with the lash caps
Re: can someone school me on lash caps on a 426 hemi? [Re: Mopar_Rich] #218736
02/09/09 04:39 PM
02/09/09 04:39 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
how much are thay?
1971 charger
Re: can someone school me on lash caps on a 426 hemi? [Re: Mopar_Rich] #218737
02/09/09 05:04 PM
02/09/09 05:04 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
ralph
It's not and absolute must,but as Mopar Rich says if you want to save your valve tip(5/16)then it is best to run them.We don't normally use them on the Indy Legends(11/32)stem unless we need added clearence or to adjust geometry.Make sure that the retainer,locks and lash caps are compatable there are a few different lengths and depths on the lash caps.
Re: can someone school me on lash caps on a 426 hemi? [Re: B G Racing] #218738
02/09/09 05:14 PM
02/09/09 05:14 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I prefer running them on engines like mine because it makes getting the valves out of the heads a couple seasons later. It beats up the lash caps instead of the valve stems.
Re: can someone school me on lash caps on a 426 hemi? [Re: Mopar_Rich] #218739
02/13/09 10:56 PM
02/13/09 10:56 PM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
i have the 619 lash caps, but 7 degree locks and retainers on my motor. the locks are not recessed and the cam is a crane hyd. roller 610 and 574 on the intake (1.7 rockers on the corners and 1.6 on the inside valves) and .555 exh. my ? is do i need to change the retainer & locks to 10 degree on this setup? street sometime strip car. thanks, dave
Re: can someone school me on lash caps on a 426 hemi? [Re: 3ddart] #218740
02/13/09 11:23 PM
02/13/09 11:23 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
The degree of the retainer and the lock must agree. So if you have 7 degree locks and 7 degree retainers you might be okay. But if the locks aren't cut or recessed for the edge of the lash cap you will have problems. It all depends on the locks. So mock one up, and see if the lash cap sits down on the valve tip as it should.
Re: can someone school me on lash caps on a 426 hemi? [Re: Mopar_Rich] #218741
02/13/09 11:44 PM
02/13/09 11:44 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I did that on the very same stuff.
Comp stuff here
741 retainers
610 valve locks
619 lash caps
Look
