Finally got myself a pair of Ladder Bars #2185765
10/30/16 12:42 PM
10/30/16 12:42 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I have a question regarding setting preload on passenger side.
I set the pinion angle on drivers side at 2degrees down, getting my measurements from driveshaft and inion yoke but want to set neutral preload.
I installed this setup, so am I just turning the lower adjuster with a wrench to get the bolt to slide freely in and out from the front eyehole? I have my son in the driver seat for proper weight.
http://chassisengineering.com/index.php?route=product/product&path=25_220&product_id=386
Re: Finally got myself a pair of Ladder Bars [Re: Sammy] #2185770
10/30/16 12:48 PM
10/30/16 12:48 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Yes. You will feel when the adjuster slackens. That will be your neutral position. Recheck your pinion angle afterwards.
[image][/image]
Re: Finally got myself a pair of Ladder Bars [Re: Sammy] #2185839
10/30/16 02:21 PM
10/30/16 02:21 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Why do you think you need preload? Run the car at neutral first, and see what it does.
69 GTX 68 Road Runner
Re: Finally got myself a pair of Ladder Bars [Re: Sammy] #2185877
10/30/16 03:01 PM
10/30/16 03:01 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
I set my bars with the nose at instant center. I added just enough preload by hand to take the slack out I guess. Goes straight for me
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Finally got myself a pair of Ladder Bars [Re: Sammy] #2185911
10/30/16 04:04 PM
10/30/16 04:04 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
It all depends on how hard the car leaves. My 63 Dodge could run no preload w/o issue. It only popped the wheels a couple inches for a foot or so. It ran mid/low ten low 1.40 60ft. My 64 Plymouth will go to the right quite a bit with no preload. Better chassis than Dodge but will carry the front wheels 40-60ft and run mid 1.20 60ft. It requires 5 flats. If you start with no preload be prepared for the car to drive to the right. Lift accordingly if it does and adjust as necessary. Just make sure it's not carrying the wheels a ways. Can be pretty spooky. Take a look at the tracks. Wheels were in the air. License run.
Doug
Re: Finally got myself a pair of Ladder Bars [Re: Sammy] #2185913
10/30/16 04:06 PM
10/30/16 04:06 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Neutral for me also
Re: Finally got myself a pair of Ladder Bars [Re: Sammy] #2185923
10/30/16 04:25 PM
10/30/16 04:25 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Thanks for all the reply's but I'm just asking for what adjuster to turn to make the adjustment for the preload?
Top or bottom long adjuster nut?
Re: Finally got myself a pair of Ladder Bars [Re: Sammy] #2185926
10/30/16 04:32 PM
10/30/16 04:32 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Bottom rear right side
Re: Finally got myself a pair of Ladder Bars [Re: Sammy] #2186129
10/30/16 08:59 PM
10/30/16 08:59 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I guess I should add this. Every non chassis door car is always drivers side heavy. Even though I tried to put everything on the right side, mine is still 1% heavy on the drivers side. Most cars I've seen on the scales are off even more. That being said, now lets scale the car. Guaranteed the right rear is light. If then car hooks well it will drive to the right. Two ways to change it. Add weight to the passenger side. Or add some preload.
Doug
