Finally got myself a pair of Ladder Bars
#2185765
10/30/16 12:42 PM
10/30/16 12:42 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
I have a question regarding setting preload on passenger side. I set the pinion angle on drivers side at 2degrees down, getting my measurements from driveshaft and inion yoke but want to set neutral preload. I installed this setup, so am I just turning the lower adjuster with a wrench to get the bolt to slide freely in and out from the front eyehole? I have my son in the driver seat for proper weight. http://chassisengineering.com/index.php?route=product/product&path=25_220&product_id=386
Re: Finally got myself a pair of Ladder Bars
[Re: Sammy]
#2185770
10/30/16 12:48 PM
10/30/16 12:48 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Yes. You will feel when the adjuster slackens. That will be your neutral position. Recheck your pinion angle afterwards.
[image][/image]
[Re: Sammy]
#2185839
10/30/16 02:21 PM
10/30/16 02:21 PM
Posts: 10,027 MN
JERICOGTX
MN
Why do you think you need preload? Run the car at neutral first, and see what it does.
69 GTX
68 Road Runner
[Re: Sammy]
#2185877
10/30/16 03:01 PM
10/30/16 03:01 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
I set my bars with the nose at instant center. I added just enough preload by hand to take the slack out I guess. Goes straight for me
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
