Page 2 of 3 1 2 3
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2180998
10/23/16 08:28 PM
10/23/16 08:28 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
So the yoke is physically longer to accommodate the spacer.... that's good to know.
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: J_BODY] #2181020
10/23/16 08:51 PM
10/23/16 08:51 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Correct,then it's easy to make something to hold the sensor.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2181080
10/23/16 10:00 PM
10/23/16 10:00 PM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
This is what I ended up doing.
Made this on the Bridgeport at work in my free time.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: J_BODY] #2196554
11/15/16 12:35 AM
11/15/16 12:35 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
well.... at least you have a yoke part number to start your D60 project with smile
It would seem that way wouldn't it? lol I just bought a Moser Billet yoke for a D60, thinking it would be like the one for my 8.75. It's not, it doesn't have room for a driveshaft collar. It would be nice to use the Moser yoke I have on my 8.75 but it is a 10 spline piece and there is no ten spline gear sets available for the Dana 60. So I emailed Moser about the 29 spline 8.75 yoke they offer and it to is different and doesn't have room for a collar. Welcome to hot rodding!
Looks Like I will check out the strange yoke that HEMITIS is using.
68 Barracuda Formula S 340
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2196561
11/15/16 12:43 AM
11/15/16 12:43 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Hemi-Itis you don't know what the ID of that sensor collar you have is do you? I am curious to see if the one I have already will work with the strange yoke. Given my luck I am sure it won't but you never know haha
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2196576
11/15/16 01:05 AM
11/15/16 01:05 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
There's a plethora of tone rings on Racepaks website. Scroll down on the price listing sheet. I ordered a 1.37 ring and will shim it to my 1.33 output shaft and am going to drill and tap the tailshaft housing.
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2197238
11/16/16 07:10 AM
11/16/16 07:10 AM
Menomonee Falls
Menomonee Falls
I put .015 shim between the halves of my ring and machined it to my pinion size, since Racepak didn't have the correct size. The .015 shims gave me the ability to machine it to the exact shaft size which would normally more than likely spin a bit, with the extra .015 it gave me clamping ability. This way the collar will never move.
SDG Motorsports
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2197262
11/16/16 11:03 AM
11/16/16 11:03 AM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Why are you putting all that time into a rear end thats a ticking tomb bomb
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2197289
11/16/16 12:20 PM
11/16/16 12:20 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
It's only a SB.........tick.... tick.... tick
hahaha
Have a great day
Iowan
"obsolete is neat"
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: J_BODY] #2197290
11/16/16 12:21 PM
11/16/16 12:21 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Yeah but I already have one with a 2.125 ID. I emailed Strange because I will more than likely use their yoke but so far no response.
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2197820
11/17/16 05:13 AM
11/17/16 05:13 AM
Menomonee Falls
Menomonee Falls
8 years and still ticking....
SDG Motorsports
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2202098
11/24/16 11:19 PM
11/24/16 11:19 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Racepak's 800CL2M137 split ring will fit on a 727 output shaft. The one I mocked it up on required a shim I made from a section of beer can (.002) to tighten up, but the trans going in the car it fit tight with no shim. It will clear the inside of the tailshaft, but due to the taper, the farther forward you can go, the more room you'll have. Bring a tap home from work tomorrow and I can button things up. A person could do this in car as the tail housing comes off pretty easy.
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2202179
11/25/16 01:19 AM
11/25/16 01:19 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Nice Work! I have seen someone mention using the park "wheel" with a sensor before, that might be something I try next time I have the trans out.
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2202186
11/25/16 02:00 AM
11/25/16 02:00 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
drilling on he rib also afforded more "meat" to tap threads into too. Another angle I thought would be to put a tone ring where where the speedo gear would mount and then tap a speedo gear housing and mount the pickup in there.... but I didn't have a stock speedo gear housing laying around to even look at. Using the park ring.... very feasible, but.... there are 18 lugs, so only two oppose each other so you still end up with a two mag signal. Would be nice if there were four opposing lugs then you could go 4 mag. Assuming drilling the lug and epoxying a couple of these flush would work... no? https://www.amazon.com/200pcs-Strong-Neo...rds=2mm+magnets
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: J_BODY] #2202376
11/25/16 03:06 PM
11/25/16 03:06 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
That's a great idea! Nice work!
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2203118
11/27/16 01:44 AM
11/27/16 01:44 AM
Menomonee Falls
Menomonee Falls
How do you set the proper clearance with a setup like that? Requires .050 to .100 clearance.
SDG Motorsports
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2203128
11/27/16 02:11 AM
11/27/16 02:11 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Divide the thread pitch into 1 inch. 1" / 16 = .0625"
One turn out from bottomed would be .0625" .
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2203147
11/27/16 02:47 AM
11/27/16 02:47 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I screwed the pickup until it bottomed out. ran the nut down to the tail shaft, unscrewed the pick up about a turn noting the gap beween the nut and the tail. Tightened the nut to lock it into place and called it good.
Since the trans was out of the car I was able to look down past the seal with a good flashlight and observe the gap also. While I did mock this up in the car with an empty case and tail shaft, I would prefer if the pickup was a lot shorter as it does stick out quite a bit. Going to see if there is a shorter one available. I'm "betting" I could cut the extra threaded part and there is just wiring inside which I could shrink wrap, but I don't want to risk ruining it as they are $129. I'll call Racepak and see what my options are. Either way, this mod cost the $45 for the split ring.
trans is back in the car and there is plenty of clearance.... but it does bother me. smile
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2257408
02/21/17 09:51 PM
02/21/17 09:51 PM
Scatchamatoon
Saskabusa Offline
Saskabusa  Offline
Scatchamatoon
1974 Roadrunner
1967 Charger
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2528397
07/28/18 08:24 PM
07/28/18 08:24 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
If you have Wilwood rear brakes you might have an easy way to add a sensor to pick up the wheel studs for wheel speed/vehicle speed.
On my Wilwood brackets there was an extra hole on the front side of the bracket that is just above the flange for the bearing. It just happens to line up perfectly with the wheel studs. For my particular sensor I had to enlarge it a little and knock the corner off of the housing end flange. I haven't driven it yet but its the same sensor and wiring as I used before I switched to the dana. I wanted to due the park wheel in the trans but this was easy and already wired haha.
This was a very rare project, it only took 30 minutes and didn't cost a dime.
Page 2 of 3 1 2 3
