Re: 62 Dart engine swap
[Re: barracudabob]
#2177591
10/18/16 11:46 AM
10/18/16 11:46 AM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
Schummacer should have the mounts and adapters.I know Imperial services had ones for the kids 62 300 years ago in poly.Oh there are no B bodys in 62 that didnt start till 65.Most call them Bs though.Dart was just mid sized car.And the lower lever trim.Rocky
Chrysler Firepower
[Re: topside]
#2177946
10/18/16 06:03 PM
10/18/16 06:03 PM
Posts: 25,801 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I've done several late k-member swaps into a '62 Dart, this moves the motor back 1 5/8" which gives more fan clearance and allows later exhaust to fit. The only real clearance problems are the pinch weld where the floorboard meets the toe board, just hammer it flat and, with a 727, some of the formed bumps in the tunnel might need massaging with a BFH.
Of course, rear trans mounts require fab and longer shift/speedo cables might be needed.
[Re: topside]
#2178254
10/19/16 12:21 AM
10/19/16 12:21 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
If the engine goes rearward, so does the trans mounting pad, and the headers or manifolds. It's a nice way to shift weight, as those cars were a bit light in the rear %-wise, but you'd be wise to mock it all up. I would assume that the 1962 S6 K has a specific mounting tower, right? Steve,the mounting surface on the S6 is flat hence the angled brackets to go to a V8.
