YEP clear bowl plugs broke #2171660
10/10/16 08:13 PM
10/10/16 08:13 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
As I was timing my engine I saw the plug drop into the valley tray and sure enough the other was broke also.I have read this topic in the past and was keeping an eye on them.Never again!
Re: YEP clear bowl plugs broke [Re: Clanton] #2171668
10/10/16 08:29 PM
10/10/16 08:29 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Yes, those are for adjusting your float levels only. Once adjusted correctly reinstall the brass plugs.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: YEP clear bowl plugs broke [Re: Clanton] #2171670
10/10/16 08:36 PM
10/10/16 08:36 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
That sounds like a reasonable use.I figured I would remind people of its danger.
Re: YEP clear bowl plugs broke [Re: Clanton] #2171748
10/10/16 10:27 PM
10/10/16 10:27 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
betting those things would turn to dust out here in a couple years.
Re: YEP clear bowl plugs broke [Re: Clanton] #2171750
10/10/16 10:29 PM
10/10/16 10:29 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Best bang for the buck. QF lightweight fuel bowls. Lighter Than Holley bowls, have a better flow pattern into the N/S, and have permanent fuel level sight glass installed.
[image][/image]
Re: YEP clear bowl plugs broke [Re: Clanton] #2171751
10/10/16 10:30 PM
10/10/16 10:30 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I have had them break after just a few minutes of use on a new build.
Re: YEP clear bowl plugs broke [Re: markz528] #2171765
10/10/16 10:47 PM
10/10/16 10:47 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
My QF carb is six years old and the sight glasses are still very clear.
Re: YEP clear bowl plugs broke [Re: YO7_A66] #2171808
10/10/16 11:48 PM
10/10/16 11:48 PM
Az
Crizila Offline
Crizila  Offline
Az
I broke some too. Easy to overtighten. Put them in by hand and they live.
Fastest 300
Re: YEP clear bowl plugs broke [Re: Crizila] #2171834
10/11/16 12:03 AM
10/11/16 12:03 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Mine didn't, they turned yellow after a couple years then broke. I'll stick with the old plug or maybe upgrade to the newer high flow bowls mentioned above. IIRC the new bowls also reduce fuel aeration in the bowl.
Re: YEP clear bowl plugs broke [Re: sgcuda] #2171847
10/11/16 12:18 AM
10/11/16 12:18 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
iagree Was my next answer...........
Re: YEP clear bowl plugs broke [Re: Thumperdart] #2171854
10/11/16 12:27 AM
10/11/16 12:27 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I just put two new bowls with the big sight glass on my carb and really like them
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: YEP clear bowl plugs broke [Re: pittsburghracer] #2171897
10/11/16 01:22 AM
10/11/16 01:22 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Anyone can benefit from the newer QF bowls and they`re light and have a nice smooth fuel path............ thumbs
Re: YEP clear bowl plugs broke [Re: Clanton] #2171918
10/11/16 01:54 AM
10/11/16 01:54 AM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
My new dominator is a qf and has the sight glass its very nice.
As to the old screw in clear ones I must be lucky. Mine are 14 yrs old and no issues. Then again I havent touched them since the fuel level was set. Not using the carb since I got the dominator this spring. I may just put in the brass ones. I'm not usually very lucky.
Ok
Re: YEP clear bowl plugs broke [Re: Clanton] #2172075
10/11/16 12:30 PM
10/11/16 12:30 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Hmmm...... work got me thinking how they may hold up to e-85,i had my carb. change over about 4/5 years ago and never had a problem yet luck Thaxs for the heads-up on this.
Re: YEP clear bowl plugs broke [Re: Clanton] #2172954
10/12/16 03:24 PM
10/12/16 03:24 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
My threads are a mess now.I can pic it out with a pin I hope.
Re: YEP clear bowl plugs broke [Re: Clanton] #2173205
10/12/16 10:39 PM
10/12/16 10:39 PM
sgcuda Offline
sgcuda  Offline
You should be able to clean that up with a pic. The plastic normally comes out pretty easy. If not, I have a couple of sets of dual feed bowls for sale cheap.
[image][/image]
Re: YEP clear bowl plugs broke [Re: Clanton] #2173210
10/12/16 10:48 PM
10/12/16 10:48 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I picked it out ok,Thx!I have the brass screws back in.I am glad I fixed it when I did.
Re: YEP clear bowl plugs broke [Re: Clanton] #2173226
10/12/16 11:02 PM
10/12/16 11:02 PM
Az
Crizila Offline
Crizila  Offline
Az
Shoulda pulled the bowls IMO. One little piece in the wrong spot and welcome to LEAN.
Fastest 300
Re: YEP clear bowl plugs broke [Re: Clanton] #2173231
10/12/16 11:05 PM
10/12/16 11:05 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I did pull the bowls
Re: YEP clear bowl plugs broke [Re: Clanton] #2173677
10/13/16 03:15 PM
10/13/16 03:15 PM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
Never liked those.... Nor trust them.... Just my 2 cents
Bob(Cowboy)Hogan
Monrovia So-Cal
