Re: YEP clear bowl plugs broke
[Re: Clanton]
#2171668
10/10/16 08:29 PM
10/10/16 08:29 PM
Posts: 4,585 Motor City
6PKRTSE
Motor City
Yes, those are for adjusting your float levels only. Once adjusted correctly reinstall the brass plugs.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Clanton]
#2171750
10/10/16 10:29 PM
10/10/16 10:29 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Best bang for the buck. QF lightweight fuel bowls. Lighter Than Holley bowls, have a better flow pattern into the N/S, and have permanent fuel level sight glass installed.
[image][/image]
[Re: Clanton]
#2171751
10/10/16 10:30 PM
10/10/16 10:30 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
I have had them break after just a few minutes of use on a new build.
[Re: markz528]
#2171765
10/10/16 10:47 PM
10/10/16 10:47 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
My QF carb is six years old and the sight glasses are still very clear.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#2171808
10/10/16 11:48 PM
10/10/16 11:48 PM
Posts: 7,506 Az
Crizila
Az
I broke some too. Easy to overtighten. Put them in by hand and they live.
Fastest 300
[Re: Crizila]
#2171834
10/11/16 12:03 AM
10/11/16 12:03 AM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
I broke some too. Easy to overtighten. Put them in by hand and they live. Mine didn't, they turned yellow after a couple years then broke. I'll stick with the old plug or maybe upgrade to the newer high flow bowls mentioned above. IIRC the new bowls also reduce fuel aeration in the bowl.
[Re: sgcuda]
#2171847
10/11/16 12:18 AM
10/11/16 12:18 AM
Thumperdart
State of confusion
Best bang for the buck. QF lightweight fuel bowls. Lighter Than Holley bowls, have a better flow pattern into the N/S, and have permanent fuel level sight glass installed. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) Was my next answer...........
[Re: Thumperdart]
#2171854
10/11/16 12:27 AM
10/11/16 12:27 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Best bang for the buck. QF lightweight fuel bowls. Lighter Than Holley bowls, have a better flow pattern into the N/S, and have permanent fuel level sight glass installed. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) Was my next answer........... I just put two new bowls with the big sight glass on my carb and really like them
[Re: pittsburghracer]
#2171897
10/11/16 01:22 AM
10/11/16 01:22 AM
Thumperdart
State of confusion
Best bang for the buck. QF lightweight fuel bowls. Lighter Than Holley bowls, have a better flow pattern into the N/S, and have permanent fuel level sight glass installed. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) Was my next answer........... I just put two new bowls with the big sight glass on my carb and really like them Anyone can benefit from the newer QF bowls and they`re light and have a nice smooth fuel path............ ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
[Re: Clanton]
#2171918
10/11/16 01:54 AM
10/11/16 01:54 AM
Posts: 1,107 Massillon, Ohio
cudatom
Massillon, Ohio
My new dominator is a qf and has the sight glass its very nice.
As to the old screw in clear ones I must be lucky. Mine are 14 yrs old and no issues. Then again I havent touched them since the fuel level was set. Not using the carb since I got the dominator this spring. I may just put in the brass ones. I'm not usually very lucky.
Ok
[Re: Clanton]
#2173205
10/12/16 10:39 PM
10/12/16 10:39 PM
sgcuda
You should be able to clean that up with a pic. The plastic normally comes out pretty easy. If not, I have a couple of sets of dual feed bowls for sale cheap.
[image][/image]
[Re: Clanton]
#2173226
10/12/16 11:02 PM
10/12/16 11:02 PM
Posts: 7,506 Az
Crizila
Az
I picked it out ok,Thx!I have the brass screws back in.I am glad I fixed it when I did. Shoulda pulled the bowls IMO. One little piece in the wrong spot and welcome to LEAN.
Fastest 300
