Re: Oil pan 360 in an A-body
[Re: Triple Threat]
#2172104
10/11/16 12:58 PM
10/11/16 12:58 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Matt and I both have the milidon oil pan and 1 7/8 headmen headers on our small blocks and had to modify two tubes with a 4 pound hammer. I just reran two tubes because our track now requires a diaper on cars going quicker than 10.99 so I'm set. I tried a Canton oil pan and I was seeing a big oil pressure drop during the shift so I put the milidon pan back on. I will address the issue on the canton pan someday with some windage work
[Re: SSDart]
#2172870
10/12/16 01:28 PM
10/12/16 01:28 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
The Milidon will not clear my headers. I'm thinking it will be the Canton pan. The website says "New" But I find that hard to believe. Unless it was re-released. As I thought they dropped that line. Good-luck. My RacePak saved me an engine.
[Re: pittsburghracer]
#2176111
10/16/16 04:01 PM
10/16/16 04:01 PM
Posts: 168 Moparts
SSDart
Moparts
I picked up the Canton pan. The baffling is awful. I'm going to change the baffling.
[Re: SSDart]
#2176288
10/16/16 08:00 PM
10/16/16 08:00 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I picked up the Canton pan. The baffling is awful. I'm going to change the baffling. The only reason I bought one was because of how nice the one was on a small block Chevy i built for a Friend. The mopar pan is a piece of crap compared to it and luckily I had a RacePak in my car to see the pressure drop.
