Oil pan 360 in an A-body #2172080
10/11/16 12:40 PM
10/11/16 12:40 PM
Moparts
SSDart Offline OP
SSDart  Offline OP
Moparts
I'm looking for a new oil pan.
I always ran a Moroso center sump, but the deep sump takes a beating coming out of wheelstands.
The Milidon will hit my headers.
I have a rear sump Dakota pan that I could modify. But I would be into a center link thru pan type deal... Not sure if I would like that.
or
I was thinking of the Canton center sump pan.
Anyone care to share there experiences?
Re: Oil pan 360 in an A-body [Re: SSDart] #2172092
10/11/16 12:49 PM
10/11/16 12:49 PM
Renton Washington
Triple Threat Offline
Renton Washington
Headers do you have?
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Oil pan 360 in an A-body [Re: Triple Threat] #2172099
10/11/16 12:54 PM
10/11/16 12:54 PM
Moparts
SSDart Offline OP
SSDart  Offline OP
Moparts
Hooker 1 3/4
Re: Oil pan 360 in an A-body [Re: Triple Threat] #2172104
10/11/16 12:58 PM
10/11/16 12:58 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Matt and I both have the milidon oil pan and 1 7/8 headmen headers on our small blocks and had to modify two tubes with a 4 pound hammer. I just reran two tubes because our track now requires a diaper on cars going quicker than 10.99 so I'm set. I tried a Canton oil pan and I was seeing a big oil pressure drop during the shift so I put the milidon pan back on. I will address the issue on the canton pan someday with some windage work
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Oil pan 360 in an A-body [Re: SSDart] #2172111
10/11/16 01:12 PM
10/11/16 01:12 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Milodon on mine with Hedmans, had to modify the pan to clear the headers though.
Re: Oil pan 360 in an A-body [Re: pittsburghracer] #2172118
10/11/16 01:18 PM
10/11/16 01:18 PM
Moparts
SSDart Offline OP
SSDart  Offline OP
Moparts
It appears the Canton has a longer sump area compared to the Moroso... I looks like the whole bucket is longer?
Re: Oil pan 360 in an A-body [Re: SSDart] #2172513
10/11/16 10:52 PM
10/11/16 10:52 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
A 7" sump on a street car is bad news even with a skid plate. Tried to ad side tanks to the pan with no success. Mounted 2 full size(1 qt. each)oil filters. Mounted them low enough to have no pressure issues. Stock pan with 6 qts. total.
Re: Oil pan 360 in an A-body [Re: SSDart] #2172738
10/12/16 09:50 AM
10/12/16 09:50 AM
Locomotion Offline
Locomotion  Offline
TTI headers fit with plenty of clearance. Great headers but not cheap, as you may know. I use Milodon pans because they are a bit shallower than a Moroso, better quality & has the drain on the back rather than bottom on Moroso. (Unless they changed it by now.)
Re: Oil pan 360 in an A-body [Re: Locomotion] #2172869
10/12/16 01:26 PM
10/12/16 01:26 PM
Moparts
SSDart Offline OP
SSDart  Offline OP
Moparts
The Milidon will not clear my headers. I'm thinking it will be the Canton pan. The website says "New" But I find that hard to believe. Unless it was re-released. As I thought they dropped that line.
Re: Oil pan 360 in an A-body [Re: SSDart] #2172870
10/12/16 01:28 PM
10/12/16 01:28 PM
PA.
"Little"John
"Little"John
PA.
Good-luck. My RacePak saved me an engine.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Oil pan 360 in an A-body [Re: SSDart] #2172911
10/12/16 02:24 PM
10/12/16 02:24 PM
midwest
superchuck Offline
On thin ice
superchuck  Offline
On thin ice
midwest
Try a Kevco oil pan.
Re: Oil pan 360 in an A-body [Re: pittsburghracer] #2176111
10/16/16 04:01 PM
10/16/16 04:01 PM
Moparts
SSDart Offline OP
SSDart  Offline OP
Moparts
I picked up the Canton pan. The baffling is awful. I'm going to change the baffling.
Re: Oil pan 360 in an A-body [Re: SSDart] #2176288
10/16/16 08:00 PM
10/16/16 08:00 PM
PA.
"Little"John
"Little"John
PA.
The only reason I bought one was because of how nice the one was on a small block Chevy i built for a Friend. The mopar pan is a piece of crap compared to it and luckily I had a RacePak in my car to see the pressure drop.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Oil pan 360 in an A-body [Re: pittsburghracer] #2176405
10/16/16 09:46 PM
10/16/16 09:46 PM
Moparts
SSDart Offline OP
SSDart  Offline OP
Moparts
It should be a good core for me to work with. Basically the same as the Moroso but not as deep. The baffles make no sense unless your a roundy rounder. The Moroso tends to hit the ground coming out of wheelstands and my last one was a dented mess. I run an oil accumulator. So I do have some insurance. How many qrts were you running in your Canton pan?
