Re: YEP clear bowl plugs broke
[Re: Clanton]
#2171668
10/10/16 08:29 PM
10/10/16 08:29 PM
Posts: 4,570 Motor City
6PKRTSE
Motor City
Yes, those are for adjusting your float levels only. Once adjusted correctly reinstall the brass plugs.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Clanton]
#2171750
10/10/16 10:29 PM
10/10/16 10:29 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Best bang for the buck. QF lightweight fuel bowls. Lighter Than Holley bowls, have a better flow pattern into the N/S, and have permanent fuel level sight glass installed.
[image][/image]
[Re: Clanton]
#2171751
10/10/16 10:30 PM
10/10/16 10:30 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
I have had them break after just a few minutes of use on a new build.
[Re: markz528]
#2171765
10/10/16 10:47 PM
10/10/16 10:47 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
My QF carb is six years old and the sight glasses are still very clear.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#2171808
10/10/16 11:48 PM
10/10/16 11:48 PM
Posts: 7,506 Az
Crizila
Az
I broke some too. Easy to overtighten. Put them in by hand and they live.
Fastest 300
[Re: Crizila]
#2171834
10/11/16 12:03 AM
10/11/16 12:03 AM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
I broke some too. Easy to overtighten. Put them in by hand and they live. Mine didn't, they turned yellow after a couple years then broke. I'll stick with the old plug or maybe upgrade to the newer high flow bowls mentioned above. IIRC the new bowls also reduce fuel aeration in the bowl.
[Re: sgcuda]
#2171847
10/11/16 12:18 AM
10/11/16 12:18 AM
Thumperdart
State of confusion
Best bang for the buck. QF lightweight fuel bowls. Lighter Than Holley bowls, have a better flow pattern into the N/S, and have permanent fuel level sight glass installed. Was my next answer...........
[Re: Thumperdart]
#2171854
10/11/16 12:27 AM
10/11/16 12:27 AM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Best bang for the buck. QF lightweight fuel bowls. Lighter Than Holley bowls, have a better flow pattern into the N/S, and have permanent fuel level sight glass installed. Was my next answer........... I just put two new bowls with the big sight glass on my carb and really like them
[Re: pittsburghracer]
#2171897
10/11/16 01:22 AM
10/11/16 01:22 AM
Thumperdart
State of confusion
Best bang for the buck. QF lightweight fuel bowls. Lighter Than Holley bowls, have a better flow pattern into the N/S, and have permanent fuel level sight glass installed. Was my next answer........... I just put two new bowls with the big sight glass on my carb and really like them Anyone can benefit from the newer QF bowls and they`re light and have a nice smooth fuel path............
[Re: Clanton]
#2171918
10/11/16 01:54 AM
10/11/16 01:54 AM
Posts: 1,102 Massillon, Ohio
cudatom
Massillon, Ohio
My new dominator is a qf and has the sight glass its very nice.
As to the old screw in clear ones I must be lucky. Mine are 14 yrs old and no issues. Then again I havent touched them since the fuel level was set. Not using the carb since I got the dominator this spring. I may just put in the brass ones. I'm not usually very lucky.
Ok
[Re: Clanton]
#2173205
10/12/16 10:39 PM
10/12/16 10:39 PM
sgcuda
You should be able to clean that up with a pic. The plastic normally comes out pretty easy. If not, I have a couple of sets of dual feed bowls for sale cheap.
[image][/image]
[Re: Clanton]
#2173226
10/12/16 11:02 PM
10/12/16 11:02 PM
Posts: 7,506 Az
Crizila
Az
I picked it out ok,Thx!I have the brass screws back in.I am glad I fixed it when I did. Shoulda pulled the bowls IMO. One little piece in the wrong spot and welcome to LEAN.
Fastest 300
[Re: 67_Satellite]
#2175214
10/15/16 12:55 PM
10/15/16 12:55 PM
Posts: 1,809 North Dakota
Azzkikrcuda
North Dakota
I had a set on my carb for 8 years and my dad still has a set in his six pack that is over ten years old with no problems. If you try remove them they will most likely break off, as mine did. I just run them for setting floats now and put the brass plugs in after that, due to the possible problems. The new ones might not be as good quality as the older ones.
The only Carbs I care about are under the hood!
[Re: 540DUSTER]
#2175538
10/15/16 11:03 PM
10/15/16 11:03 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
plastic expands more than metal do not over tighten,make sure orings are soft. OR put them in the trash.Maybe you can make a tq wrench for them.j/k
[Re: Clanton]
#2175573
10/15/16 11:50 PM
10/15/16 11:50 PM
Posts: 3,517 pacific northwest
Stroker Scamp
pacific northwest
they sure didn't like E85 either
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: Stroker Scamp]
#2177622
10/18/16 12:29 PM
10/18/16 12:29 PM
Posts: 1,318 Ohio
jlatessa
Ohio
Another heads-up on this subject, We dodged a engine fire by the skin of our teeth yesterday.
Took off the air cleaner housing on our six pack and noticed I had forgotten about the broken plastic fuel level window on the rear carb after a dyno session.
Took the carb off, removed the bowl to drill out the remainder of the sight glass...well, when I touched the plastic with the drill bit, it went through it like a piece of plastic wrap!!
We weren't far from a fire happening. found a piece if the plastic in the bottom of the bowl that had the consistency of chewing gum.
These were the Holley parts, so BEWARE!!!
Joe
[Re: jlatessa]
#2177691
10/18/16 02:36 PM
10/18/16 02:36 PM
Thumperdart
State of confusion
Other than a nostalgia look, it makes no sense NOT to use the modern dual sight glass bowls or maybe modify stock ones and make your own. They have saved my azz a few times over the years like when you're warming up your car and all looks/sounds good but you see the glass solid w/fuel. The N&S had a piece of rubber fuel line stuck in it which hung it open and I caught it luckily.................
