auto choke #2167138
10/03/16 04:41 PM
10/03/16 04:41 PM
Eastern ohio
Alexdodge Offline OP
Eastern ohio
Where would be the best place to connect the hot lead for the auto choke?
Re: auto choke [Re: Alexdodge] #2167147
10/03/16 05:04 PM
10/03/16 05:04 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
What kind of choke? Aftermarket like a holley or edelbrock you can tie into the power wire that feeds the coil, so long as you do it before the ballast resistor. Best is to follow the wire back to where it gets its power from, mine has a junction relay block on the firewall with a switched 12v feed. Stock chokes with electric assist need the temp switch that threads into the intake manifold or else the choke will open too fast.
Re: auto choke [Re: Alexdodge] #2167221
10/03/16 06:54 PM
10/03/16 06:54 PM
Eastern ohio
Eastern ohio
Its a edelbrock choke. Its now connected to the hot side of the tallest resistor but it seems to open way to fast.
Re: auto choke [Re: Alexdodge] #2167228
10/03/16 07:03 PM
10/03/16 07:03 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
To delay the opening, turn the black plastic housing in the direction of the arrow. Turning the housing tightens the spring that closes the choke butterfly, so more tension on the spring will cause the choke to stay closed longer.
Re: auto choke [Re: Alexdodge] #2167230
10/03/16 07:10 PM
10/03/16 07:10 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I've read that the Edelbrock chokes open way too fast. Wouldn't hooking the power up AFTER the ballast lower the power to the choke...letting it open slower?
Re: auto choke [Re: Alexdodge] #2167246
10/03/16 07:27 PM
10/03/16 07:27 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
I don't think it would open completely with low voltage.
Re: auto choke [Re: stumpy] #2167290
10/03/16 08:54 PM
10/03/16 08:54 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I spliced the electric choke hot wire on my E-Brock #1406 to the field wire that goes to the alternator...NOT the power wire. The field wire is a light gauge and is only hot when the key is on.
The instructions do say not to wire to the alternator and I am sure they say that so that a Chevy guy does not burn his car to the ground smile
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: auto choke [Re: Alexdodge] #2167295
10/03/16 09:00 PM
10/03/16 09:00 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Realize that as soon as you turn your key the electric choke starts to warm and begins to open....
So if you turn on your key without starting your car for a bit you lose some of the carb choke....
Re: auto choke [Re: DaytonaTurbo] #2167347
10/03/16 10:16 PM
10/03/16 10:16 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I wire that into my Ebrock chokes as well, worked fine for me.
Don't be the exception.
