Gas Pedal Swap? #2164581
09/29/16 07:01 PM
09/29/16 07:01 PM
Airdrie, AB
Mills Offline OP
Mills  Offline OP
Airdrie, AB
I had to weld in a new drivers-side floor pan in my '67 Satellite and it does not have the gas pedal square "boss" to accept the stock floor bolt-down type pedal so reusing my stock pedal isn't gonna work.
I know for later years / different body styles the pedal does not bolt to the floor - is there something I can do to easily convert or ?? I was thinking about just hacking off the floor boss on the pedal, removing the "roller" on the pedal linkage, and just bolting the [censored] on...but that seems like a hack-job haha
Suggestions on what to do / buy to make this work. No bone-yard searching please
Thx
1967 Satellite, CNC Eddy Headed 500ci Street Mauler
(Dyno'ed @ 600 HP / 650 ft-lbs)
2016 Challenger Hellcat - Holy Hell
2012 Hemi Ram Sport Crew Cab
2011 Avenger, Pentastar V-6
2007 SRT-8 Charger (Dyno'ed @ 470 RWHP)
1986 Caravelle, 318, aka "Rosco", Back Road Burner!
ALL Black...Bad Boys always wear Black!
Re: Gas Pedal Swap? [Re: Mills] #2164628
09/29/16 08:13 PM
09/29/16 08:13 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Maybe Lokar has something you can use.
Re: Gas Pedal Swap? [Re: stumpy] #2164636
09/29/16 08:23 PM
09/29/16 08:23 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I know a 72 Duster has the pedal mounted on the firewall without touching the floor.
Might be as simple as drilling a couple holes. You may be able to reuse your old cable too... shruggy
...FAFO...
Re: Gas Pedal Swap? [Re: skicker] #2164789
09/29/16 11:30 PM
09/29/16 11:30 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
How about a later B-body? (mid-'70's)
Back when I had my '76 Dodge Club Cab, it had a gas pedal that mounted to the floor. I hated it. It felt awkward to me.
I was able to mount a pedal assembly from an early '80's truck in its place. I don't remember if I had to elongate one of the holes, or drill a new one, but, it was really simple.
John
Re: Gas Pedal Swap? [Re: Mills] #2164907
09/30/16 02:38 AM
09/30/16 02:38 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
What are you talking about here?? The floor pan is flat on 67 B-bodies. I'll go out and get a picture to avoid the ensuing argument.
Re: Gas Pedal Swap? [Re: Mills] #2164925
09/30/16 03:21 AM
09/30/16 03:21 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Pic 1 Shows a bare floor and it is flat. pic 2 You can see the blue floor has the pedal sitting on the lat floor.
The way the gas pedal is installed is there is a rectangular hole cut in the heel pad in the carpet. A rectangle shaped white foam piece goes under the carpet to hold the heel pad up so the gas pedal sits flush on the heel pad.
Bare floor, and the blue one has no carpet and the pedal is sitting on the floor.
Re: Gas Pedal Swap? [Re: NANKET] #2165076
09/30/16 01:12 PM
09/30/16 01:12 PM
Airdrie, AB
Mills Offline OP
Mills  Offline OP
Airdrie, AB
Wow - did I ever pay close attn to what I cut out haha. I swore there was the rectangular boss...but that clearly shows I was smoking in the garage that day
Many thx NANKET!!
Re: Gas Pedal Swap? [Re: Mills] #2165279
09/30/16 06:23 PM
09/30/16 06:23 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Glad to help out.
