Gas Pedal Swap?
#2164581
09/29/16 07:01 PM
09/29/16 07:01 PM
Posts: 1,379 Airdrie, AB
Mills
Airdrie, AB
I had to weld in a new drivers-side floor pan in my '67 Satellite and it does not have the gas pedal square "boss" to accept the stock floor bolt-down type pedal so reusing my stock pedal isn't gonna work.
I know for later years / different body styles the pedal does not bolt to the floor - is there something I can do to easily convert or ?? I was thinking about just hacking off the floor boss on the pedal, removing the "roller" on the pedal linkage, and just bolting the [censored] on...but that seems like a hack-job haha
Suggestions on what to do / buy to make this work. No bone-yard searching please
Thx
1967 Satellite, CNC Eddy Headed 500ci Street Mauler (Dyno'ed @ 600 HP / 650 ft-lbs)
2016 Challenger Hellcat - Holy Hell 2012 Hemi Ram Sport Crew Cab 2011 Avenger, Pentastar V-6 2007 SRT-8 Charger (Dyno'ed @ 470 RWHP) 1986 Caravelle, 318, aka "Rosco", Back Road Burner!
ALL Black...Bad Boys always wear Black!
Re: Gas Pedal Swap?
[Re: stumpy]
#2164636
09/29/16 08:23 PM
09/29/16 08:23 PM
Posts: 5,107 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
I know a 72 Duster has the pedal mounted on the firewall without touching the floor. Might be as simple as drilling a couple holes. You may be able to reuse your old cable too...
...FAFO...
Re: Gas Pedal Swap?
[Re: skicker]
#2164789
09/29/16 11:30 PM
09/29/16 11:30 PM
Posts: 16,826 Between Houston & Galveston TX
SattyNoCar
How about a later B-body? (mid-'70's)
Back when I had my '76 Dodge Club Cab, it had a gas pedal that mounted to the floor. I hated it. It felt awkward to me.
I was able to mount a pedal assembly from an early '80's truck in its place. I don't remember if I had to elongate one of the holes, or drill a new one, but, it was really simple.
John
Re: Gas Pedal Swap?
[Re: NANKET]
#2165076
09/30/16 01:12 PM
09/30/16 01:12 PM
Mills
Airdrie, AB
What are you talking about here?? The floor pan is flat on 67 B-bodies. I'll go out and get a picture to avoid the ensuing argument. Wow - did I ever pay close attn to what I cut out haha. I swore there was the rectangular boss...but that clearly shows I was smoking in the garage that day Many thx NANKET!!
