Jesel alignment problem
#2157682
09/19/16 08:20 PM
09/19/16 08:20 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
On my 588 inch motor, I have Indy 572-13 heads, With jesel 1.7 rocker arms. Two of the intake arms do not line up with the valve tip. The others are OK and all the exhaust are perfect. I would like a opinions on if these are okay to run? Cam is a solid roller. .800". This is going in A Streetcar.
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: Jesel alignment problem
[Re: Old School]
#2157688
09/19/16 08:32 PM
09/19/16 08:32 PM
Thumperdart
State of confusion
Needs to be shimmed to center the valve tip...........
[Re: Thumperdart]
#2157691
09/19/16 08:34 PM
09/19/16 08:34 PM
Old School
Virginia Beach, VA
Needs to be shimmed to center the valve tip........... reading about Gregsdart, I don't want to bind the bearing cages, and have the failures he is dealing with.....
[Re: Dave Hall]
#2157709
09/19/16 08:56 PM
09/19/16 08:56 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Shims and spacers are usually required, all are ok as long as the rocker has SIDE clearance. Those are controlled by the snap ring.. they are wrong.. send them back for replacements.. they should line up perfectly... you dont put spacers on those EDIT send Jesel a pic of them so they see the issue.. they will replace them.... if need be they can move the snap ring grooves over to center the rockers if they are in spec now.. they may charge you for that.. but it would be cheap.. how is the push rod on those 2 sets.. does the push rod show to be off... measure what it takes to center them so you can tell Jesel
[Re: 440Jim]
#2157821
09/19/16 11:25 PM
09/19/16 11:25 PM
Old School
Virginia Beach, VA
I agree with Mr.P. The location is fixed by the snap rings on the shafts. Either the head valve location is wrong, or the rocker offset on those two is wrong. I would not run them that way with 0.800" lift. Swap them from another cylinder and find out which is wrong. being that they are indy heads, I would not be surprised if it was the heads. I will move the 2 around and see if the problem follows them.
[Re: Dave Hall]
#2157833
09/19/16 11:36 PM
09/19/16 11:36 PM
MR_P_BODY
It sure looks like a spacer sitting there on the left in the second image. The rockers are held in place between two grooves in the shaft for snap rings? The grooves providing ample side clearance? That so called spacer is there so the side of the bearing doesnt ride on the snap ring.. it might be abile to be cut down some but it has to be in there.. then you have to add that amount to the other side
[Re: Old School]
#2157839
09/19/16 11:45 PM
09/19/16 11:45 PM
MR_P_BODY
I agree with Mr.P. The location is fixed by the snap rings on the shafts. Either the head valve location is wrong, or the rocker offset on those two is wrong. I would not run them that way with 0.800" lift. Swap them from another cylinder and find out which is wrong. being that they are indy heads, I would not be surprised if it was the heads. I will move the 2 around and see if the problem follows them. IF the guides were off we all know that you wouldnt pull the heads off and send them back to see IF they can or will fix them so you have to work around it.. you could have jesel move them or get 2 shafts with just the mount holes and do your own snap rings grooves.. JMO.. I have the equipment to do it so I would do it myself
[Re: Dave Hall]
#2157855
09/20/16 12:14 AM
09/20/16 12:14 AM
MR_P_BODY
So it spaces the bearing away from the snap ring. What would you call it Mr. P? I'm just looking at the second image posted and if that piece in there to the left of the "spacer" is the snap ring, looks like ample clearance to move that "spacer" to the other side of the bearing and have a whatever smaller "spacer" to keep the bearing off the snap ring to the left. He could try it.. but that spacer needs to have some strength to it.. I'm sure its just nylon.. I dont know how much he can get trying that
