Jesel alignment problem #2157682
09/19/16 08:20 PM
09/19/16 08:20 PM
Virginia Beach, VA
O
Old School Offline OP
O
Virginia Beach, VA
On my 588 inch motor, I have Indy 572-13 heads, With jesel 1.7 rocker arms. Two of the intake arms do not line up with the valve tip. The others are OK and all the exhaust are perfect. I would like a opinions on if these are okay to run? Cam is a solid roller. .800". This is going in A Streetcar.
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: Jesel alignment problem [Re: Old School] #2157685
09/19/16 08:25 PM
09/19/16 08:25 PM
Virginia Beach, VA
O
O
Virginia Beach, VA
The other one...
Re: Jesel alignment problem [Re: Old School] #2157688
09/19/16 08:32 PM
09/19/16 08:32 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Needs to be shimmed to center the valve tip...........
Re: Jesel alignment problem [Re: Thumperdart] #2157691
09/19/16 08:34 PM
09/19/16 08:34 PM
Virginia Beach, VA
O
O
Virginia Beach, VA
reading about Gregsdart, I don't want to bind the bearing cages, and have the failures he is dealing with.....
Re: Jesel alignment problem [Re: Old School] #2157692
09/19/16 08:35 PM
09/19/16 08:35 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
It looks as if you could use a spacer on the right side of the rocker in the first image. It looks like the spacer on the left side of the rocker could be moved to the right in the second image. I would try to get them as centered as possible. Maybe the hold downs can move around providing different offsets as to which pedestal they bolt to? Maybe some machining of the hold down is necessary?
Re: Jesel alignment problem [Re: Old School] #2157693
09/19/16 08:36 PM
09/19/16 08:36 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I would call Jesel. Mine were perfect on my w9s. Not real sure on shimming.
Re: Jesel alignment problem [Re: Dave Hall] #2157695
09/19/16 08:39 PM
09/19/16 08:39 PM
Virginia Beach, VA
O
O
Virginia Beach, VA
I might try to remove all of them, and try mixing them up to get the best alignment. would they be ok to run like they are? confused
Re: Jesel alignment problem [Re: Old School] #2157697
09/19/16 08:41 PM
09/19/16 08:41 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
It will not I already tried that.
Re: Jesel alignment problem [Re: Old School] #2157701
09/19/16 08:45 PM
09/19/16 08:45 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Too many $$'s invested to run them like that. Take your time and get it right.
Re: Jesel alignment problem [Re: Old School] #2157703
09/19/16 08:47 PM
09/19/16 08:47 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Shims and spacers are usually required, all are ok as long as the rocker has SIDE clearance.
Re: Jesel alignment problem [Re: Dave Hall] #2157709
09/19/16 08:56 PM
09/19/16 08:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Those are controlled by the snap ring.. they are wrong..
send them back for replacements.. they should line up
perfectly... you dont put spacers on those
EDIT
send Jesel a pic of them so they see the issue.. they will
replace them.... if need be they can move the snap ring
grooves over to center the rockers if they are in spec
now.. they may charge you for that.. but it would be cheap..
how is the push rod on those 2 sets.. does the push rod show
to be off... measure what it takes to center them so
you can tell Jesel
wave
Re: Jesel alignment problem [Re: Old School] #2157711
09/19/16 08:59 PM
09/19/16 08:59 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
If swapping rockers didn't change anything they're not the issue. If the bolt holes in the stands all measure the same, which I'd bet they do. That leaves the valve guides not in the "print" location. The fix? Shim the rockers over or rework the heads.
Doug
Re: Jesel alignment problem [Re: Old School] #2157799
09/19/16 11:03 PM
09/19/16 11:03 PM
NC
440Jim Offline
440Jim  Offline
NC
I agree with Mr.P. The location is fixed by the snap rings on the shafts.
Either the head valve location is wrong, or the rocker offset on those two is wrong. I would not run them that way with 0.800" lift. Swap them from another cylinder and find out which is wrong.
Re: Jesel alignment problem [Re: Old School] #2157804
09/19/16 11:08 PM
09/19/16 11:08 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
It sure looks like a spacer sitting there on the left in the second image. The rockers are held in place between two grooves in the shaft for snap rings? The grooves providing ample side clearance?
Re: Jesel alignment problem [Re: 440Jim] #2157821
09/19/16 11:25 PM
09/19/16 11:25 PM
Virginia Beach, VA
O
O
Virginia Beach, VA
being that they are indy heads, I would not be surprised if it was the heads. I will move the 2 around and see if the problem follows them. frown
Re: Jesel alignment problem [Re: Dave Hall] #2157833
09/19/16 11:36 PM
09/19/16 11:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That so called spacer is there so the side of the bearing
doesnt ride on the snap ring.. it might be abile to be cut
down some but it has to be in there.. then you have to add
that amount to the other side
wave
Re: Jesel alignment problem [Re: Old School] #2157839
09/19/16 11:45 PM
09/19/16 11:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
IF the guides were off we all know that you wouldnt
pull the heads off and send them back to see IF they
can or will fix them so you have to work around it..
you could have jesel move them or get 2 shafts with
just the mount holes and do your own snap rings grooves..
JMO.. I have the equipment to do it so I would do it myself
wave
Re: Jesel alignment problem [Re: Old School] #2157853
09/20/16 12:06 AM
09/20/16 12:06 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
So it spaces the bearing away from the snap ring. What would you call it Mr. P? I'm just looking at the second image posted and if that piece in there to the left of the "spacer" is the snap ring, looks like ample clearance to move that "spacer" to the other side of the bearing and have a whatever smaller "spacer" to keep the bearing off the snap ring to the left.
Re: Jesel alignment problem [Re: Dave Hall] #2157855
09/20/16 12:14 AM
09/20/16 12:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
He could try it.. but that spacer needs to have some
strength to it.. I'm sure its just nylon.. I dont know
how much he can get trying that
wave
Re: Jesel alignment problem [Re: Old School] #2157862
09/20/16 12:19 AM
09/20/16 12:19 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Look at the first image. Do you see anything between the bearing and the snap ring to the rocker on the far right? Something is definitely wrong here. Maybe the shaft swaps end to end?
