Exhaust gasket #2156527
09/17/16 11:42 PM
09/17/16 11:42 PM
70duster340 Offline OP
With E-heads and the stock exhaust manifolds, what gaskets do you all recommend (if any)? This is on a 1970 Duster with a 340.
Thanks in advance!😁
Re: Exhaust gasket [Re: 70duster340] #2156539
09/18/16 12:04 AM
09/18/16 12:04 AM
the regular felpro ones that are sort of silvery on one side are OK but check for overhang/trim as needed OR no gasket & a thin coat of "the right stuff" gasket maker
Re: Exhaust gasket [Re: 70duster340] #2156634
09/18/16 03:40 AM
09/18/16 03:40 AM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
No gasket on mine.
Re: Exhaust gasket [Re: 70duster340] #2156646
09/18/16 04:37 AM
09/18/16 04:37 AM
Wouldn't there be a problem with differing metals being together, or is that just with cylinder heads?
Re: Exhaust gasket [Re: 70duster340] #2156677
09/18/16 09:52 AM
09/18/16 09:52 AM
IN
ahy Offline
ahy  Offline
IN
I use a little bit of high temp RTV on mine (Ed heads, thick flange headers) and would do the same with manifolds. No gasket to blow out. It has been through some hard running and one freshen and no issue since I got rid of the gaskets early on.
You probably have this covered but I'll mention its a good idea to get the manifolds skim cut for a flat smooth sealing surface.
Re: Exhaust gasket [Re: 70duster340] #2156805
09/18/16 01:43 PM
09/18/16 01:43 PM
no problem, Ma did em dry (on BB at least) but that was with flat surfaces to start with. A light amt of gasket maker works fine/cheap/easy
Re: Exhaust gasket [Re: 70duster340] #2156825
09/18/16 02:22 PM
09/18/16 02:22 PM
I was concerned about dissimilar metals being in contact without a gasket between them.
Re: Exhaust gasket [Re: 70duster340] #2156840
09/18/16 02:56 PM
09/18/16 02:56 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
http://www.jegs.com/i/Cometic-Gaskets/245/C5901-030/10002/-1
MLS exhaust gasket by Cometic, about $40.
Don't be the exception.
