Exhaust gasket
#2156527
09/17/16 11:42 PM
09/17/16 11:42 PM
70duster340
With E-heads and the stock exhaust manifolds, what gaskets do you all recommend (if any)? This is on a 1970 Duster with a 340.
Thanks in advance!😁
Re: Exhaust gasket
[Re: 70duster340]
#2156539
09/18/16 12:04 AM
09/18/16 12:04 AM
RapidRobert
the regular felpro ones that are sort of silvery on one side are OK but check for overhang/trim as needed OR no gasket & a thin coat of "the right stuff" gasket maker
Re: Exhaust gasket
[Re: 70duster340]
#2156805
09/18/16 01:43 PM
09/18/16 01:43 PM
RapidRobert
Wouldn't there be a problem with differing metals being together, or is that just with cylinder heads? no problem, Ma did em dry (on BB at least) but that was with flat surfaces to start with. A light amt of gasket maker works fine/cheap/easy
