i avoided a 727 explosion ,,,,, #2155337
09/15/16 10:02 PM
09/15/16 10:02 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
i broke 8 teeth on my 8 3/4 last friday at dragstrip on launch.decided to pull the tranny and check the sprag,sure enough it cracked the case in 2 spots and collapsed the wave springs,it was a bolt in stock style sprag.valvebody is a reverse pattern low band apply style.
Re: i avoided a 727 explosion ,,,,, [Re: hp340nos] #2155395
09/15/16 11:20 PM
09/15/16 11:20 PM
You did the proper thing up bow When in doubt, always check it out up
Re: i avoided a 727 explosion ,,,,, [Re: hp340nos] #2155402
09/15/16 11:25 PM
09/15/16 11:25 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
That's what made me go dana. I didn't mind the maintenance on the 8&3/4 but when it took the trans out I stopped seeing the banjo as neet.
Re: i avoided a 727 explosion ,,,,, [Re: FastmOp] #2155416
09/15/16 11:40 PM
09/15/16 11:40 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
One of the few occasions I fixed a problem before it became a problem.
Re: i avoided a 727 explosion ,,,,, [Re: hp340nos] #2155417
09/15/16 11:42 PM
09/15/16 11:42 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Could have gone A833 instead, and never have to worry about sprags again devil
Re: i avoided a 727 explosion ,,,,, [Re: hp340nos] #2155420
09/15/16 11:45 PM
09/15/16 11:45 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
sticks are for popsicles....
Re: i avoided a 727 explosion ,,,,, [Re: hp340nos] #2155440
09/16/16 12:14 AM
09/16/16 12:14 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I'll never give up my pushbuttons!!!!!!!!!!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: i avoided a 727 explosion ,,,,, [Re: hemi-itis] #2155446
09/16/16 12:26 AM
09/16/16 12:26 AM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
thats funny because im buiding a dana 60 also
Re: i avoided a 727 explosion ,,,,, [Re: hp340nos] #2155448
09/16/16 12:31 AM
09/16/16 12:31 AM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
do u guys use bolt in sprags or just the one that is pressed in the case stock.im wondering because the bolt in one i used cracked the case,because it couldnt spin the outer piece,it spun everything in the center though.let here opinions on this
Re: i avoided a 727 explosion ,,,,, [Re: hp340nos] #2155487
09/16/16 01:18 AM
09/16/16 01:18 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
the two race cars I've had both have run the stock sprag.
Re: i avoided a 727 explosion ,,,,, [Re: hp340nos] #2155497
09/16/16 01:30 AM
09/16/16 01:30 AM
Regina Sask, Canada
V
Viper469 Offline
Viper469  Offline
V
Regina Sask, Canada
The picture i posted in your other thread was of a stock sprag. It also cracked the case.
Re: i avoided a 727 explosion ,,,,, [Re: hp340nos] #2155519
09/16/16 02:33 AM
09/16/16 02:33 AM
Queensland
N
NOM36 Offline
NOM36  Offline
N
Queensland
I had a stock sprag do the same. They are in there nice and tight.
Super Sprag and the like have higher holding force.
Re: i avoided a 727 explosion ,,,,, [Re: hp340nos] #2155541
09/16/16 07:25 AM
09/16/16 07:25 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Super sprag is an upgrade, more rollers. Though Idid see one bust last year when a rear end broke. The stock style bolt in piece is no better than a stocker in my opinion
Doug
Re: i avoided a 727 explosion ,,,,, [Re: hp340nos] #2155554
09/16/16 09:00 AM
09/16/16 09:00 AM
Minn
SportF Offline
SportF  Offline
Minn
I think no matter what sprag you have in there, when you hammer it with broke teeth on a ring gear, she is going to break. The sprag DVW talked about above was the strongest sprag available but still broke. BUT, it held and kept the engine from over reving.
Re: i avoided a 727 explosion ,,,,, [Re: hemi-itis] #2155561
09/16/16 09:43 AM
09/16/16 09:43 AM
jersey
Spaceman Spiff Offline
jersey
Don't push my buttons!!
Nothing like a reverse manual push button car!
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: i avoided a 727 explosion ,,,,, [Re: Spaceman Spiff] #2155590
09/16/16 11:03 AM
09/16/16 11:03 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Mmmmmmmmm, LOVE my powerglide. LOL
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: i avoided a 727 explosion ,,,,, [Re: J_BODY] #2155602
09/16/16 11:15 AM
09/16/16 11:15 AM
Maryland
twayne24365 Offline
twayne24365  Offline
Maryland
I'm not sure how true it is, but the shop that rebuilt my dad's 727 said the bot in sprag is no better than the stock unit
Re: i avoided a 727 explosion ,,,,, [Re: DrCharles] #2155604
09/16/16 11:17 AM
09/16/16 11:17 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Until the gears lock up on the shaft and the trans locks and your car skids through the traps and possibly into the wall.... yup replacing a car is way cooler than replacing a sprag
Re: i avoided a 727 explosion ,,,,, [Re: twayne24365] #2155615
09/16/16 11:23 AM
09/16/16 11:23 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I had inquired about the bolt in unit, as well as the "super sprag" and it wasn't deemed a necessity by my builder. I can do a 727, but when it comes down to the fine details of getting a shift to take place quickly and efficiently... that's a gray area for sure.
Re: i avoided a 727 explosion ,,,,, [Re: hp340nos] #2155650
09/16/16 12:15 PM
09/16/16 12:15 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
A stock style bolt in sprag is a complete waste of time and money , as you can see it did NOTHING to stop it from rolling. The purpose of it is to replace an outer race that is lose in the trans case.
The best bolt in sprags are not cheap ... A+A or Coan ... and should not let the rollers roll over, but with enough force they could break the case still.
When I install one I use the 6 bolt and machine to add the extra 2 bolts under the rear support.
