Re: i avoided a 727 explosion ,,,,,
[Re: hp340nos]
#2155395
09/15/16 11:20 PM
09/15/16 11:20 PM
Posts: 43,259 Bend,OR USA
Cab_Burge
You did the proper thing When in doubt, always check it out
[Re: FastmOp]
#2155416
09/15/16 11:40 PM
09/15/16 11:40 PM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
That's what made me go dana. I didn't mind the maintenance on the 8&3/4 but when it took the trans out I stopped seeing the banjo as neet. One of the few occasions I fixed a problem before it became a problem.
[Re: hp340nos]
#2155417
09/15/16 11:42 PM
09/15/16 11:42 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
Could have gone A833 instead, and never have to worry about sprags again
[Re: hp340nos]
#2155440
09/16/16 12:14 AM
09/16/16 12:14 AM
Posts: 12,589 Great Neck,LI,new york
hemi-itis
I'll never give up my pushbuttons!!!!!!!!!!
[Re: hp340nos]
#2155497
09/16/16 01:30 AM
09/16/16 01:30 AM
Posts: 88 Regina Sask, Canada
Viper469
Regina Sask, Canada
do u guys use bolt in sprags or just the one that is pressed in the case stock.im wondering because the bolt in one i used cracked the case,because it couldnt spin the outer piece,it spun everything in the center though.let here opinions on this The picture i posted in your other thread was of a stock sprag. It also cracked the case.
[Re: hp340nos]
#2155541
09/16/16 07:25 AM
09/16/16 07:25 AM
Posts: 9,865 MI, usa
dvw
MI, usa
Super sprag is an upgrade, more rollers. Though Idid see one bust last year when a rear end broke. The stock style bolt in piece is no better than a stocker in my opinion Doug
[Re: hp340nos]
#2155554
09/16/16 09:00 AM
09/16/16 09:00 AM
Posts: 1,213 Minn
SportF
Minn
I think no matter what sprag you have in there, when you hammer it with broke teeth on a ring gear, she is going to break. The sprag DVW talked about above was the strongest sprag available but still broke. BUT, it held and kept the engine from over reving.
[Re: hemi-itis]
#2155561
09/16/16 09:43 AM
09/16/16 09:43 AM
Posts: 3,696 jersey
Spaceman Spiff
jersey
I'll never give up my pushbuttons!!!!!!!!!! Don't push my buttons!! Nothing like a reverse manual push button car!
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: Spaceman Spiff]
#2155590
09/16/16 11:03 AM
09/16/16 11:03 AM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Mmmmmmmmm, LOVE my powerglide. LOL
[Re: J_BODY]
#2155602
09/16/16 11:15 AM
09/16/16 11:15 AM
Posts: 181 Maryland
twayne24365
Maryland
the two race cars I've had both have run the stock sprag. I'm not sure how true it is, but the shop that rebuilt my dad's 727 said the bot in sprag is no better than the stock unit
[Re: DrCharles]
#2155604
09/16/16 11:17 AM
09/16/16 11:17 AM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
Could have gone A833 instead, and never have to worry about sprags again Until the gears lock up on the shaft and the trans locks and your car skids through the traps and possibly into the wall.... yup replacing a car is way cooler than replacing a sprag
[Re: twayne24365]
#2155615
09/16/16 11:23 AM
09/16/16 11:23 AM
J_BODY
aZLiViN
the two race cars I've had both have run the stock sprag. I'm not sure how true it is, but the shop that rebuilt my dad's 727 said the bot in sprag is no better than the stock unit I had inquired about the bolt in unit, as well as the "super sprag" and it wasn't deemed a necessity by my builder. I can do a 727, but when it comes down to the fine details of getting a shift to take place quickly and efficiently... that's a gray area for sure.
[Re: hp340nos]
#2155650
09/16/16 12:15 PM
09/16/16 12:15 PM
Posts: 75,080 U.S.S.A.
JohnRR
U.S.S.A.
do u guys use bolt in sprags or just the one that is pressed in the case stock.im wondering because the bolt in one i used cracked the case,because it couldnt spin the outer piece,it spun everything in the center though.let here opinions on this A stock style bolt in sprag is a complete waste of time and money , as you can see it did NOTHING to stop it from rolling. The purpose of it is to replace an outer race that is lose in the trans case. The best bolt in sprags are not cheap ... A+A or Coan ... and should not let the rollers roll over, but with enough force they could break the case still. When I install one I use the 6 bolt and machine to add the extra 2 bolts under the rear support.
