Should my K frame look like this? #215323
02/05/09 08:55 PM
02/05/09 08:55 PM
Hunt Valley, Maryland
1fastrunner Offline OP
Here's a picture of the bottom of my K frame. It looks like it's concave in the middle and has some metal overlapping. Is this the way it should look?
Re: Should my K frame look like this? [Re: 1fastrunner] #215324
02/05/09 08:56 PM
02/05/09 08:56 PM
#2
Re: Should my K frame look like this? [Re: 1fastrunner] #215325
02/05/09 08:57 PM
02/05/09 08:57 PM
#3
Re: Should my K frame look like this? [Re: 1fastrunner] #215326
02/05/09 08:57 PM
02/05/09 08:57 PM
Last One
Re: Should my K frame look like this? [Re: 1fastrunner] #215327
02/05/09 10:33 PM
02/05/09 10:33 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
tough to tell from the photos but it looks damaged to me
Re: Should my K frame look like this? [Re: A12] #215328
02/05/09 10:41 PM
02/05/09 10:41 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
here's the bottom of an undamaged K-frame, can you tell if it is like your's?
Re: Should my K frame look like this? [Re: A12] #215329
02/05/09 11:02 PM
02/05/09 11:02 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
thats the result of floor jack use.
Re: Should my K frame look like this? [Re: 05dakota] #215330
02/05/09 11:05 PM
02/05/09 11:05 PM
Kirkland, Washington
Pacnorthcuda Offline
exactly. VERY common. Mine always look worse on every car I buy
Re: Should my K frame look like this? [Re: Pacnorthcuda] #215331
02/06/09 12:19 AM
02/06/09 12:19 AM
So, it should be replaced?
Re: Should my K frame look like this? [Re: 1fastrunner] #215332
02/06/09 02:28 AM
02/06/09 02:28 AM
Georgia,Douglasville
streaker Offline
streaker  Offline
I believe this is what a K frame should look like
I said Don't look Ethel, It was too late
Re: Should my K frame look like this? [Re: streaker] #215333
02/06/09 09:15 AM
02/06/09 09:15 AM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
If you have a welder, you can cut out the damaged area, pound it straight and reweld back on. I know someone who did that and at the same time from the back reinforced that area so it does not happen again.
Re: Should my K frame look like this? [Re: A12] #215334
02/06/09 10:59 AM
02/06/09 10:59 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Definitely is , combo of jacking it there AND bottoming out .
1fastrunner , whats the original engine for your car ??? you could HIDE that damage by adding a repop skidplate
Re: Should my K frame look like this? [Re: JohnRR] #215335
02/06/09 11:29 AM
02/06/09 11:29 AM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
I agree with it appearing damaged and here is my factory K-member outta my '72 Gtx a plate will protect and cover that. I don't know how the repo plates fit...
Re: Should my K frame look like this? [Re: JohnRR] #215336
02/06/09 11:37 AM
02/06/09 11:37 AM
It was a factory 383 car, are those skid plates available?
Thanks,
Re: Should my K frame look like this? [Re: 1fastrunner] #215337
02/06/09 11:47 AM
02/06/09 11:47 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Thanks,
your car would not have had one , if it did it would be bashed in also as the factory one isn't that stout . If your pan is hanging below the K , which it looks like , you definitely want to add one . Yes a repop is available from the usual sources ...
Re: Should my K frame look like this? [Re: JohnRR] #215338
02/06/09 11:50 AM
02/06/09 11:50 AM
You should see the old pan (7qt.), it was jb welded and duct taped at a Syracuse show the driven to Rochester. It's now hanging on the wall in my garage(duct tape and all).
Re: Should my K frame look like this? [Re: 1fastrunner] #215339
02/06/09 03:47 PM
02/06/09 03:47 PM
California
mickm Offline
mickm  Offline
California
how bout a picture, that should be fun to see
btw, i put one of the repop skid plates on mine... not sure how well it will fit with all that damage though. you would have to put it in place and see if it will work. it doesn't look like it will hide all that damage either, so depends how much you want to put into it.
isn't that always the question.
Re: Should my K frame look like this? [Re: 1fastrunner] #215340
02/07/09 08:54 PM
02/07/09 08:54 PM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
Yes, the skid plates are available. I was at the Columbia Mo swap meet and saw that MegaParts had them new for about $75-$80.
Re: Should my K frame look like this? [Re: moparmojo] #215341
02/08/09 04:59 PM
02/08/09 04:59 PM
Thanks, maybe I'll add one to my new k frame after I find one.
Re: Should my K frame look like this? [Re: 1fastrunner] #215342
02/08/09 06:11 PM
02/08/09 06:11 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Are you worried about it's appearance or structural integrity? If the LCA pivot tubes aren't damaged, and the car held a wheel alignment, I can't see why a new K frame would be needed. I would remove it, clean it up, touch up all the factory welds, and fashion a skid plate from plate steel. I think the Car Farmer web site had some skid plates for sale at one time but they are not in business, but it would give some ideas of what to fab up.
