Rocker shaft holddowns? #215275
02/05/09 06:54 PM
02/05/09 06:54 PM
Stockholm,SWEDEN
The Nutcracker Offline OP
Stockholm,SWEDEN
Any good holddowns out there? My shafts where oval!
-70 Cuda,-65 Valiant,-66 Valiant,-62 FED
Re: Rocker shaft holddowns? [Re: The Nutcracker] #215276
02/05/09 08:02 PM
02/05/09 08:02 PM
AndyF Offline
AndyF  Offline
RAS hold downs are very good. Hughes has some that are good. I prefer the heavy duty steel hold downs rather than the aluminum. Width varies by mfg so be prepared to modify parts in order to get the correct alignment.
Re: Rocker shaft holddowns? [Re: AndyF] #215277
02/05/09 08:11 PM
02/05/09 08:11 PM
IN
ahy Offline
ahy  Offline
IN
I used the MP hold downs (aluminum) with good results. They did require light milling on the sides to gain clearance and shimming to line rockers up with the valves. Whatever you choose, you'll likley need several packs of shims.
Re: Rocker shaft holddowns? [Re: ahy] #215278
02/05/09 08:35 PM
02/05/09 08:35 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: Rocker shaft holddowns? [Re: The Nutcracker] #215279
02/05/09 10:39 PM
02/05/09 10:39 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I agree with Andy. I like the steel hold downs much better. I use the Harland Sharps, dont get any beefier than that. The RAS are essentially the same as well.
RIP Monte Smith
Re: Rocker shaft holddowns? [Re: 70AARcuda] #215280
02/05/09 10:43 PM
02/05/09 10:43 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
I got these from Hughes Engines. Around 40 bucks.
Re: Rocker shaft holddowns? [Re: The Nutcracker] #215281
02/06/09 02:11 PM
02/06/09 02:11 PM
I like and use the RAS brand, oval shafst are uaually caused by over torqueing. The factory torque spesc. are 25 ft. lbs. Yoo may be able to make them round again with some side pressure like in a vise or a press, be careful so you don't make them collapse or make them worse I have had to grind on the ends to ge the aftermarket rockers to slide on and off after someone had over tighten them instead of using the factory torque specs.
Re: Rocker shaft holddowns? [Re: The Nutcracker] #215282
02/06/09 02:40 PM
02/06/09 02:40 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
what kind of shafts were they? Stock or heavy duty new ones.
I bought a set of heavy duty shafts and they also went oval when I got to 15 ftlbs on the bolts.
I ended up getting some really nice hard chromed shafts from RAS and they didnt crush at all. The RAS Shafts had allen screws in the ends in stead of little freeze plug like caps
Re: Rocker shaft holddowns? [Re: The Nutcracker] #215283
02/06/09 07:08 PM
02/06/09 07:08 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Mancini has the deal on the Hughes holddowns with ARP hardware included.Mine should be here tomorrow with the AR engineering motor plate.I cant wait until Fluffy shows up at the BE/A party with my stuff
Gus
64 Plymouth Savoy
Dana 60
Re: Rocker shaft holddowns? [Re: fourgearsavoy] #215284
02/06/09 07:27 PM
02/06/09 07:27 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Mancini has the deal on the Hughes hold downs with ARP hardware included.
Got my Hughes hold down kit from Mancini too.
Re: Rocker shaft holddowns? [Re: The Nutcracker] #215285
02/06/09 09:02 PM
02/06/09 09:02 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
I dont know how well you can see them in this pic...I bought them from Mancini..
Re: Rocker shaft holddowns? [Re: CompWedgeEngines] #215286
02/09/09 01:33 PM
02/09/09 01:33 PM
Fl. USA
PS Arrow Offline
PS Arrow  Offline
Fl. USA
I have not heard of the RAS, can anybody provide info please?
Re: Rocker shaft holddowns? [Re: PS Arrow] #215287
02/09/09 01:46 PM
02/09/09 01:46 PM
RAS ph. # 530-378-1075, there located in Anderson, CA
Re: Rocker shaft holddowns? [Re: Cab_Burge] #215288
02/09/09 02:28 PM
02/09/09 02:28 PM
Fl. USA
PS Arrow Offline
PS Arrow  Offline
Fl. USA
Do they have a web site, I Googled RAS and didnt come up with anything, well nothing pertaining to performance equipment.
Re: Rocker shaft holddowns? [Re: PS Arrow] #215289
02/09/09 03:01 PM
02/09/09 03:01 PM
AndyF Offline
AndyF  Offline
Re: Rocker shaft holddowns? [Re: AndyF] #215290
02/09/09 04:45 PM
02/09/09 04:45 PM
Fl. USA
PS Arrow Offline
PS Arrow  Offline
Fl. USA
Thanks,
Looks like some very top shelf parts!!!
Re: Rocker shaft holddowns? [Re: AndyF] #215291
02/09/09 05:35 PM
02/09/09 05:35 PM
Boise
Moparteacher Offline
Boise
RAS manufactures the steel hold downs sold by Hughes and Mancini.
