Rocker shaft holddowns?
#215275
02/05/09 06:54 PM
02/05/09 06:54 PM
Posts: 282 Stockholm,SWEDEN
The Nutcracker
Stockholm,SWEDEN
Any good holddowns out there? My shafts where oval!
-70 Cuda,-65 Valiant,-66 Valiant,-62 FED
Re: Rocker shaft holddowns?
[Re: The Nutcracker]
#215279
02/05/09 10:39 PM
02/05/09 10:39 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I agree with Andy. I like the steel hold downs much better. I use the Harland Sharps, dont get any beefier than that. The RAS are essentially the same as well.
RIP Monte Smith
#215282
02/06/09 02:40 PM
02/06/09 02:40 PM
Posts: 15,491 the boonies
aarcuda
the boonies
what kind of shafts were they? Stock or heavy duty new ones.
I bought a set of heavy duty shafts and they also went oval when I got to 15 ftlbs on the bolts.
I ended up getting some really nice hard chromed shafts from RAS and they didnt crush at all. The RAS Shafts had allen screws in the ends in stead of little freeze plug like caps
[Re: fourgearsavoy]
#215284
02/06/09 07:27 PM
02/06/09 07:27 PM
Posts: 3,333 MARYLAND
69Cuda340S
MARYLAND
Mancini has the deal on the Hughes hold downs with ARP hardware included.
Got my Hughes hold down kit from Mancini too.
[Re: PS Arrow]
#215287
02/09/09 01:46 PM
02/09/09 01:46 PM
Posts: 43,181 Bend,OR USA
Cab_Burge
I have not heard of the RAS, can anybody provide info please?
RAS ph. # 530-378-1075, there located in Anderson, CA
