Re: Sway Bar Dimensions
[Re: C-MORE]
#2151806
09/10/16 08:14 PM
09/10/16 08:14 PM
Posts: 27 Indiana
dusterpt440
Indiana
So we're having a really hard time finding a sway bar for our 24 Hours of Lemons Valiant (see: https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2076847/re-24-hours-of-lemons.html) that will keep us under budget. I was wondering if someone with an OEM bar could take some measurements based on the diagram below so I can scour the junkyard and see if I can find something that's close in size from something late model (pre 1980 cars are non existent in junkyards here). what year bar are you looking for? I've got one I'll sell you dirt cheap for a 73-76 a body
[Re: TC@HP2]
#2152699
09/11/16 10:34 PM
09/11/16 10:34 PM
Posts: 7 Virginia
C-MORE
Virginia
Data I have based on some bars in my garage is below. However, I believe the A body unit I have is a '74 and there are variations to earlier bars that I do not have. I also have an added dimension in a straight line from your dimension A to C but do not have the overall width, dim C
70+ B and E body A=27" B=10.125" C=no data D=8" pre 70 B A=27" B=19.5" C=no data D=17.5" A body A=23.5"B=15.5" C=no data D=12.25
I'd love to get more info on other options out there as well.
GM F bodies and GM trucks may be options. You can always trim the link arm length down to what you need. Awesome numbers, thanks! I was thinking something along the lines of a Dakota or S10 bar might be close.
[Re: dusterpt440]
#2152702
09/11/16 10:35 PM
09/11/16 10:35 PM
Posts: 7 Virginia
C-MORE
Virginia
So we're having a really hard time finding a sway bar for our 24 Hours of Lemons Valiant (see: https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2076847/re-24-hours-of-lemons.html) that will keep us under budget. I was wondering if someone with an OEM bar could take some measurements based on the diagram below so I can scour the junkyard and see if I can find something that's close in size from something late model (pre 1980 cars are non existent in junkyards here). what year bar are you looking for? I've got one I'll sell you dirt cheap for a 73-76 a body What are the differences between pre 72 and 73-76 a body bars? I was under the impression the front suspension was virtually unchanged.
[Re: autoxcuda]
#2152704
09/11/16 10:37 PM
09/11/16 10:37 PM
Posts: 7 Virginia
C-MORE
Virginia
You are looking for a 67-72 a-body front bar, correct?
The 66-69 b-body bar is very close and just about 1" wider overall. End link bushing could be tweaked in lemons fashion to fit.
Do you have away bar tabs on your LCA's? If not you could fit a narrower bar eyelet to eyelet if the other dimensions worked. The aftermarket Hotchkis bar is like that. You'd loose rate, but that could be made up by a thicker bar. Sorry, should have been more specific, yes, the front is primarily what I'm looking for, rear should be easier and not as essential. What's the difference between 67-72 and 73+? No tabs - I'm assuming I'll have to weld some angle iron or something to the front of the LCA to attach the end link to.
[Re: C-MORE]
#2152761
09/11/16 11:18 PM
09/11/16 11:18 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Tab location changed.
Early A bodies are different than later ones as well.
[Re: C-MORE]
#2152816
09/12/16 12:17 AM
09/12/16 12:17 AM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
Late bar needs the bottom of the k-member opened up for the bar to pass through. It will not work on an unmodified 67-72 k-member.
[Re: C-MORE]
#2152954
09/12/16 10:03 AM
09/12/16 10:03 AM
Supercuda
About to go away
About to go away
up yours
Years ago I put the front sway bar from an 89 Ram into my 64 300, Tape measure told the tale.
