Re: Ignition Buzzer
[Re: Airgrabber]
#2146959
09/03/16 08:10 PM
09/03/16 08:10 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Does anyone make an aftermarket version or do I need to buy an "expensive" NOS ignition buzzer? When I was doing my 70 Charger dash install, I got one from CarQuest, but you'll need to go thru the electrical mfg catalogs they have on hand, as it won't be in the computer program, I might be able to dig up the info for you later?....maybe?
Re: Ignition Buzzer
[Re: Airgrabber]
#2146991
09/03/16 09:18 PM
09/03/16 09:18 PM
Posts: 3,528 Lansing, MI
70gtx440dana
Lansing, MI
I have a bunch of used originals. Give me the part number and I will check. I can also test for function. Joe
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Ignition Buzzer
[Re: Airgrabber]
#2147030
09/03/16 10:27 PM
09/03/16 10:27 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Does anyone make an aftermarket version or do I need to buy an "expensive" NOS ignition buzzer? Year, Make, model might help.
Re: Ignition Buzzer
[Re: Airgrabber]
#2147937
09/05/16 01:07 PM
09/05/16 01:07 PM
70gtx440dana
Lansing, MI
Sorry do not have a working buzzer for 70 RR.
Re: Ignition Buzzer
[Re: Airgrabber]
#2149410
09/07/16 09:01 AM
09/07/16 09:01 AM
Posts: 1,499 Slidell, LA
Plum440
Slidell, LA
Not to hijack this thread but my buzzer only works when passenger door is open, not driver's door. Is this correct or is something not connected? Door jamb switch operates cabin light with no issues. Car is 70 Challenger. Thanks!
70 Challenger, 440, 4-speed, pLuM cRaZy 71 VW Super Beetle Convertible, Lemon Yellow A couple of Jeeps…
Re: Ignition Buzzer
[Re: Plum440]
#2149755
09/07/16 05:33 PM
09/07/16 05:33 PM
Posts: 403 Pittsburgh, PA
Slotts
Pittsburgh, PA
Not to hijack this thread but my buzzer only works when passenger door is open, not driver's door. Is this correct or is something not connected? Door jamb switch operates cabin light with no issues. Car is 70 Challenger. Thanks! The driver's side door jamb switch has two wires connected to it. One solid yellow wire runs to the rear harness that connects to the dome light. (M2B-18Y) The second wire is yellow w/ black tracer (M6B-18Y*) that runs to a female single bullet connector for the delay light wiring sub harness. A second wire at that female connector (M6A-18Y*) continues to the 2983696 buzzer relay that is a dual wire connection at the relay terminal with the passenger's side door jamb switch wire (M6-18Y*). Long story short, ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) either the left or right door when opened should make the buzzer work, if the key is in the ignition switch. It could be as simple as the M6B-18Y* is not connected onto the door jamb switch terminal. Jim
Re: Ignition Buzzer
[Re: Airgrabber]
#2149837
09/07/16 07:15 PM
09/07/16 07:15 PM
Posts: 25,992 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Not sure what years but in some years the key buzzer and the horn relay are combined. Affects interchangeability.
