Ignition Buzzer #2146856
09/03/16 04:44 PM
09/03/16 04:44 PM
Pewaukee, WI
Airgrabber Offline OP
Pewaukee, WI
Does anyone make an aftermarket version or do I need to buy an "expensive" NOS ignition buzzer?
Re: Ignition Buzzer [Re: Airgrabber] #2146955
09/03/16 08:05 PM
09/03/16 08:05 PM
Pewaukee, WI
Pewaukee, WI
Anyone out there? whistling
Re: Ignition Buzzer [Re: Airgrabber] #2146958
09/03/16 08:10 PM
09/03/16 08:10 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
You sure are impatient. Give it some time and you will eventually get an answer. grin
Re: Ignition Buzzer [Re: Airgrabber] #2146959
09/03/16 08:10 PM
09/03/16 08:10 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
When I was doing my 70 Charger dash install, I got one from CarQuest, but you'll need to go thru the electrical mfg catalogs they have on hand, as it won't be in the computer program, I might be able to dig up the info for you later?....maybe?
Re: Ignition Buzzer [Re: Airgrabber] #2146991
09/03/16 09:18 PM
09/03/16 09:18 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
I have a bunch of used originals. Give me the part number and I will check. I can also test for function. Joe
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Ignition Buzzer [Re: Airgrabber] #2147030
09/03/16 10:27 PM
09/03/16 10:27 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Year, Make, model might help.
Don't be the exception.
Re: Ignition Buzzer [Re: Airgrabber] #2147040
09/03/16 10:47 PM
09/03/16 10:47 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Sorry I could get to this thread earlier. Work keeps getting in the way.
Re: Ignition Buzzer [Re: Airgrabber] #2147685
09/05/16 12:16 AM
09/05/16 12:16 AM
Pewaukee, WI
Pewaukee, WI
The buzzer would be for a 1970 Plymouth road runner.
Re: Ignition Buzzer [Re: Airgrabber] #2147937
09/05/16 01:07 PM
09/05/16 01:07 PM
Lansing, MI
Lansing, MI
Sorry do not have a working buzzer for 70 RR.
Re: Ignition Buzzer [Re: Airgrabber] #2148725
09/06/16 12:41 PM
09/06/16 12:41 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Buzzer (key warning) for 1970 B body, part number 3420885 . . .not sure if you will find NOS one, but maybe you can take that number and cross it to after market . . .happy hunting !!
Cheers
Mark
Re: Ignition Buzzer [Re: Airgrabber] #2148737
09/06/16 12:57 PM
09/06/16 12:57 PM
None
71rm23 Offline
71rm23  Offline
None
http://www.ebay.com/itm/NOS-MOPAR-1970-P...5-/271758108439
Says "NOS". Not mine BTW. In fact, found three and not cheap. Ebay "mopar 3420885"
Re: Ignition Buzzer [Re: Airgrabber] #2149361
09/07/16 02:04 AM
09/07/16 02:04 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Re: Ignition Buzzer [Re: Airgrabber] #2149410
09/07/16 09:01 AM
09/07/16 09:01 AM
Slidell, LA
Plum440 Offline
Plum440  Offline
Slidell, LA
Not to hijack this thread but my buzzer only works when passenger door is open, not driver's door. Is this correct or is something not connected? Door jamb switch operates cabin light with no issues. Car is 70 Challenger. Thanks!
70 Challenger, 440, 4-speed, pLuM cRaZy
71 VW Super Beetle Convertible, Lemon Yellow
A couple of Jeeps…
Re: Ignition Buzzer [Re: Plum440] #2149755
09/07/16 05:33 PM
09/07/16 05:33 PM
Pittsburgh, PA
Slotts Offline
Slotts  Offline
Pittsburgh, PA
The driver's side door jamb switch has two wires connected to it. One solid yellow wire runs to the rear harness that connects to the dome light. (M2B-18Y)
The second wire is yellow w/ black tracer (M6B-18Y*) that runs to a female single bullet connector for the delay light wiring sub harness. A second wire at that female connector (M6A-18Y*) continues to the 2983696 buzzer relay that is a dual wire connection at the relay terminal with the passenger's side door jamb switch wire (M6-18Y*).
Long story short, wink either the left or right door when opened should make the buzzer work, if the key is in the ignition switch.
It could be as simple as the M6B-18Y* is not connected onto the door jamb switch terminal.
Re: Ignition Buzzer [Re: Airgrabber] #2149831
09/07/16 07:10 PM
09/07/16 07:10 PM
Pewaukee, WI
Pewaukee, WI
So JS Restorations informed me:
The 2983695 is the actual part number stamped into the relay and the 3420885 would be the "over the counter in box" version sold by the parts department at the dealership. Are there another aftermarket ones being produced? Generally where would I locate the buzzer. A guy at NAPA said they can get one for a '71 any difference and would it still work?
Thank you!
Re: Ignition Buzzer [Re: Airgrabber] #2149837
09/07/16 07:15 PM
09/07/16 07:15 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Not sure what years but in some years the key buzzer and the horn relay are combined. Affects interchangeability.
