Page 2 of 3 1 2 3
Re: Green bearings ÉÉ [Re: Stanton] #2147354
09/04/16 03:30 PM
09/04/16 03:30 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
A+ in engish and never took an auto mechanics class. LOL!!
Re: Green bearings ÉÉ [Re: Stanton] #2147976
09/05/16 01:42 PM
09/05/16 01:42 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
Some claim tapered are the only way to go....I've used the green bearings for years...beat the cars up...never had a problem....with the rearend
Re: Green bearings ÉÉ [Re: terzmo] #2148013
09/05/16 02:39 PM
09/05/16 02:39 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Agreed, same here, decades of use and abuse running Green Bearings, zero issues or failures on any of my vehicles or customers, most people are just "lipping" hersay/myths they have heard, from my experience with others that may have had issues or failures, it seems to stem from installation errors on their behalf
Re: Green bearings ÉÉ [Re: Stanton] #2148026
09/05/16 03:08 PM
09/05/16 03:08 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
On a Roundy round car, green bearings wont finish one race, that should tell you something .
Re: Green bearings ÉÉ [Re: Stanton] #2148044
09/05/16 03:35 PM
09/05/16 03:35 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
We're not driving roundy round cars
Don't be the exception.
Re: Green bearings ÉÉ [Re: Supercuda] #2148057
09/05/16 03:55 PM
09/05/16 03:55 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
LMAO
Re: Green bearings ÉÉ [Re: Supercuda] #2148064
09/05/16 04:07 PM
09/05/16 04:07 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Maybe not roundy round cars but crisp mountain canyon driving.
Train cars use tapers for high flange loads, no green bearings.
Craig
Re: Green bearings ÉÉ [Re: CSK] #2148112
09/05/16 05:00 PM
09/05/16 05:00 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I've been slinging cars around tracks for decades on Green Bearings, "roundy round/stock car", road course, 1/4 mile, parking lot gymkhana, street racing, etc, etc...never an issue on Greens, although I have toasted a few factory tapered bearings
Re: Green bearings ÉÉ [Re: DAYCLONA] #2148126
09/05/16 05:12 PM
09/05/16 05:12 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
you must not go very fast or hard into a corner smile
Re: Green bearings ÉÉ [Re: Stanton] #2148138
09/05/16 05:28 PM
09/05/16 05:28 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I would bet that the spiral clip that some greens have would bail out before the ball bearing would wear out on nasty side loads. That being said I DID cash a pair of greens in a thousand miles due to my own hackery, by leaving the adjuster block in place with a new pair of mosers that were designed for adjuster block absent center section..
Re: Green bearings ÉÉ [Re: Stanton] #2148155
09/05/16 06:00 PM
09/05/16 06:00 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
I have owned dozens of mopars, always service the wheel bearings, never have a tapered roller bearing fail. NO REASON to ever buy a poor designed green bearing.
Re: Green bearings ÉÉ [Re: NANKET] #2148452
09/06/16 12:41 AM
09/06/16 12:41 AM
Cab_Burge Online work
Cab_Burge  Online Work
For those that do not know that the Green type axle bearings, all of them, are ball bearings, nothing more, nothing less shruggy
They work, but there not the best for long hard aggressive street or track racing twocents
Think about the contact surfaces on a ball bearing and race and then the same on a tapered Timken roller bearing, how many ball bearings, the O.D. of the balls in each green bearing and how many tapered roller bearings and how much supporting surface contact there is on them work scope
Re: Green bearings ÉÉ [Re: Cab_Burge] #2148647
09/06/16 10:12 AM
09/06/16 10:12 AM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
More specific, I believe the Green bearings are double row ball bearings. Years ago I looked up the design specifications for both the stock and the greens. IIRC, the tapered roller bearings had something like 4x the side load capacity of the green bearings. But, the green bearing side loading was pretty high. Again, something like a 4g skid pad type of turn would have to be needed to get to the design load of the green bearing. I know my Road Runner isn't capable of 4g turns on a skid pad. But constant side loading could shorten the life of the bearing. This is going back a ways when I looked this up, maybe like 20 years ago.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Green bearings ÉÉ [Re: Stanton] #2148712
09/06/16 12:26 PM
09/06/16 12:26 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Some rear disc brake kits aren't compatible with the stock bearings. Sometimes you HAVE to use green bearings.
Re: Green bearings ÉÉ [Re: Stanton] #2148715
09/06/16 12:29 PM
09/06/16 12:29 PM
an8sec70cuda Offline
Been using green bearings on the street and strip for the last 15+ years. No issues.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Green bearings ÉÉ [Re: RoadRunner] #2148716
09/06/16 12:32 PM
09/06/16 12:32 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Finally we are getting some factual data instead of opinions.
Both bearing designs will function if used within their design parameters. Due to the design differences their life expectancy will be compromised when they are used in less than ideal conditions. Ball bearings preceded the Timken design by several decades. The Timken design was developed to overcome the shortcomings of the ball bearing in demanding applications.
Pretty simple really twocents beer
Re: Green bearings ÉÉ [Re: TJP] #2148834
09/06/16 02:43 PM
09/06/16 02:43 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
If all this stuff about side loading was really that important to street and race cars, all of us would be using full-floating truck rear ends in our cars like they use in NASCAR....
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Green bearings ÉÉ [Re: TJP] #2148852
09/06/16 03:01 PM
09/06/16 03:01 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
they are not double row bearings
Re: Green bearings ÉÉ [Re: Stanton] #2148858
09/06/16 03:08 PM
09/06/16 03:08 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
I have been running a set of Green Bearings in my 70 dart for 15+ years now. No issues.
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: Green bearings ÉÉ [Re: 19swinger70] #2148875
09/06/16 03:24 PM
09/06/16 03:24 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
argue I've been hearing these arguments for and against greens for 40 years and still no concensus. shruggy
Page 2 of 3 1 2 3
