Re: Green bearings ÉÉ
[Re: terzmo]
#2148013
09/05/16 02:39 PM
09/05/16 02:39 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Some claim tapered are the only way to go....I've used the green bearings for years...beat the cars up...never had a problem....with the rearend Agreed, same here, decades of use and abuse running Green Bearings, zero issues or failures on any of my vehicles or customers, most people are just "lipping" hersay/myths they have heard, from my experience with others that may have had issues or failures, it seems to stem from installation errors on their behalf
[Re: Stanton]
#2148026
09/05/16 03:08 PM
09/05/16 03:08 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
On a Roundy round car, green bearings wont finish one race, that should tell you something .
[Re: Stanton]
#2148044
09/05/16 03:35 PM
09/05/16 03:35 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
We're not driving roundy round cars
[Re: Supercuda]
#2148057
09/05/16 03:55 PM
09/05/16 03:55 PM
CSK
Pattison Texas
We're not driving roundy round cars LMAO
[Re: Supercuda]
#2148064
09/05/16 04:07 PM
09/05/16 04:07 PM
Posts: 1,822 Colorado
denfireguy
Colorado
We're not driving roundy round cars Maybe not roundy round cars but crisp mountain canyon driving. Train cars use tapers for high flange loads, no green bearings. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: CSK]
#2148112
09/05/16 05:00 PM
09/05/16 05:00 PM
Posts: 18,157 Mass
DAYCLONA
Mass
On a Roundy round car, green bearings wont finish one race, that should tell you something . I've been slinging cars around tracks for decades on Green Bearings, "roundy round/stock car", road course, 1/4 mile, parking lot gymkhana, street racing, etc, etc...never an issue on Greens, although I have toasted a few factory tapered bearings
[Re: DAYCLONA]
#2148126
09/05/16 05:12 PM
09/05/16 05:12 PM
CSK
Pattison Texas
On a Roundy round car, green bearings wont finish one race, that should tell you something . I've been slinging cars around tracks for decades on Green Bearings, "roundy round/stock car", road course, 1/4 mile, parking lot gymkhana, street racing, etc, etc...never an issue on Greens, although I have toasted a few factory tapered bearings you must not go very fast or hard into a corner
[Re: NANKET]
#2148452
09/06/16 12:41 AM
09/06/16 12:41 AM
Posts: 43,218 Bend,OR USA
Cab_Burge
For those that do not know that the Green type axle bearings, all of them, are ball bearings, nothing more, nothing less They work, but there not the best for long hard aggressive street or track racing Think about the contact surfaces on a ball bearing and race and then the same on a tapered Timken roller bearing, how many ball bearings, the O.D. of the balls in each green bearing and how many tapered roller bearings and how much supporting surface contact there is on them
[Re: Cab_Burge]
#2148647
09/06/16 10:12 AM
09/06/16 10:12 AM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
For those that do not know that the Green type axle bearings, all of them, are ball bearings, nothing more, nothing less They work, but there not the best for long hard aggressive street or track racing Think about the contact surfaces on a ball bearing and race and then the same on a tapered Timken roller bearing, how many ball bearings, the O.D. of the balls in each green bearing and how many tapered roller bearings and how much supporting surface contact there is on them More specific, I believe the Green bearings are double row ball bearings. Years ago I looked up the design specifications for both the stock and the greens. IIRC, the tapered roller bearings had something like 4x the side load capacity of the green bearings. But, the green bearing side loading was pretty high. Again, something like a 4g skid pad type of turn would have to be needed to get to the design load of the green bearing. I know my Road Runner isn't capable of 4g turns on a skid pad. But constant side loading could shorten the life of the bearing. This is going back a ways when I looked this up, maybe like 20 years ago.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: Stanton]
#2148712
09/06/16 12:26 PM
09/06/16 12:26 PM
Posts: 7,369 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
NO REASON to ever buy a poor designed green bearing. Some rear disc brake kits aren't compatible with the stock bearings. Sometimes you HAVE to use green bearings.
[Re: Stanton]
#2148715
09/06/16 12:29 PM
09/06/16 12:29 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
Been using green bearings on the street and strip for the last 15+ years. No issues.
[Re: RoadRunner]
#2148716
09/06/16 12:32 PM
09/06/16 12:32 PM
Posts: 15,408 Omaha Ne
TJP
Omaha Ne
For those that do not know that the Green type axle bearings, all of them, are ball bearings, nothing more, nothing less They work, but there not the best for long hard aggressive street or track racing Think about the contact surfaces on a ball bearing and race and then the same on a tapered Timken roller bearing, how many ball bearings, the O.D. of the balls in each green bearing and how many tapered roller bearings and how much supporting surface contact there is on them More specific, I believe the Green bearings are double row ball bearings. Years ago I looked up the design specifications for both the stock and the greens. IIRC, the tapered roller bearings had something like 4x the side load capacity of the green bearings. But, the green bearing side loading was pretty high. Again, something like a 4g skid pad type of turn would have to be needed to get to the design load of the green bearing. I know my Road Runner isn't capable of 4g turns on a skid pad. But constant side loading could shorten the life of the bearing. This is going back a ways when I looked this up, maybe like 20 years ago. Finally we are getting some factual data instead of opinions. Both bearing designs will function if used within their design parameters. Due to the design differences their life expectancy will be compromised when they are used in less than ideal conditions. Ball bearings preceded the Timken design by several decades. The Timken design was developed to overcome the shortcomings of the ball bearing in demanding applications. Pretty simple really
[Re: TJP]
#2148834
09/06/16 02:43 PM
09/06/16 02:43 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
If all this stuff about side loading was really that important to street and race cars, all of us would be using full-floating truck rear ends in our cars like they use in NASCAR....
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: TJP]
#2148852
09/06/16 03:01 PM
09/06/16 03:01 PM
CSK
Pattison Texas
For those that do not know that the Green type axle bearings, all of them, are ball bearings, nothing more, nothing less They work, but there not the best for long hard aggressive street or track racing Think about the contact surfaces on a ball bearing and race and then the same on a tapered Timken roller bearing, how many ball bearings, the O.D. of the balls in each green bearing and how many tapered roller bearings and how much supporting surface contact there is on them More specific, I believe the Green bearings are double row ball bearings. Years ago I looked up the design specifications for both the stock and the greens. IIRC, the tapered roller bearings had something like 4x the side load capacity of the green bearings. But, the green bearing side loading was pretty high. Again, something like a 4g skid pad type of turn would have to be needed to get to the design load of the green bearing. I know my Road Runner isn't capable of 4g turns on a skid pad. But constant side loading could shorten the life of the bearing. This is going back a ways when I looked this up, maybe like 20 years ago. Finally we are getting some factual data instead of opinions. Both bearing designs will function if used within their design parameters. Due to the design differences their life expectancy will be compromised when they are used in less than ideal conditions. Ball bearings preceded the Timken design by several decades. The Timken design was developed to overcome the shortcomings of the ball bearing in demanding applications. Pretty simple really they are not double row bearings
[Re: Stanton]
#2148858
09/06/16 03:08 PM
09/06/16 03:08 PM
Posts: 3,923 Richmond, Indiana
19swinger70
Richmond, Indiana
I have been running a set of Green Bearings in my 70 dart for 15+ years now. No issues.
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
