Re: What is this wire for?
[Re: buildanother]
#2144427
08/31/16 09:46 AM
08/31/16 09:46 AM
Posts: 1,229 In The Hills
jughed
In The Hills
Looks like some non factory wiring there. Will be wild guesses. yep...no heat shrink tubing on factory wiring. May be just a new end piece. Best way to find out where it goes is to trace it back to find the original wire color and look it up in a factory wiring diagram.
[Re: jayyohe]
#2144508
08/31/16 12:09 PM
08/31/16 12:09 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
It's next to impossible to even GUESS what that non factory wire is for.
Did you pull the ignition module that is right there off ? if someone with half a brain wired it then black would be a GROUND wire , was it under the bolt holding the module on since you think you have no spark ?
[Re: jayyohe]
#2144556
08/31/16 01:49 PM
08/31/16 01:49 PM
RapidRobert
So I'm battling starter heat soak issues. I've swapped starters - didn't help. I've added a heat shield to my starter - didn't help. I've wrapped header tube that passes by starter with fiberglass header wrap - didn't help. get it good and hot. shut it off. pull & ground the coil wire or pull the ECU pentastar connector (work fast while it is still hot). Now see if it cranks
[Re: jayyohe]
#2145343
09/01/16 01:12 PM
09/01/16 01:12 PM
Posts: 198 Stinnett, Tx
rumblebee4232
Stinnett, Tx
Decided to change my starter relay. Took a bunch of before pictures then got lazy and didn't finish project for at least a month and when I put everything back together I wasn't sure if this black wire was grounded under the starter relay or connected to the starter relay slug.
So where are the before pictures??
