What is this wire for? #2144329
08/31/16 01:22 AM
08/31/16 01:22 AM
Export, PA
jayyohe Offline OP
jayyohe  Offline OP
Export, PA
So I'm battling starter heat soak issues. I've swapped starters - didn't help. I've added a heat shield to my starter - didn't help. I've wrapped header tube that passes by starter with fiberglass header wrap - didn't help. Decided to change my starter relay. Took a bunch of before pictures then got lazy and didn't finish project for at least a month and when I put everything back together I wasn't sure if this black wire was grounded under the starter relay or connected to the starter relay slug. I connected it to the slug and when I reconnected the battery I heard a click. Disconnected and then reconnected battery and heard another softer click. Everything seemed in order so tried to start car. It turns over but I can tell it's not getting any spark. So does anybody know what this wire is for and where it should get connected? 1971 Demon. Thanks everyone.
jayyohe@yahoo.com Export, PA 1971 Dodge Demon - 440/4-Speed
Re: What is this wire for? [Re: jayyohe] #2144371
08/31/16 03:25 AM
08/31/16 03:25 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Looks like some non factory wiring there. Will be wild guesses.
Re: What is this wire for? [Re: jayyohe] #2144379
08/31/16 04:21 AM
08/31/16 04:21 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Looks like a coil wire but you didn't touch that.
Re: What is this wire for? [Re: buildanother] #2144427
08/31/16 09:46 AM
08/31/16 09:46 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
yep...no heat shrink tubing on factory wiring. May be just a new end piece.
Best way to find out where it goes is to trace it back to find the original wire color and look it up in a factory wiring diagram.
Re: What is this wire for? [Re: jayyohe] #2144466
08/31/16 11:12 AM
08/31/16 11:12 AM
Export, PA
jayyohe Offline OP
jayyohe  Offline OP
Export, PA
Re: What is this wire for? [Re: jayyohe] #2144508
08/31/16 12:09 PM
08/31/16 12:09 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
It's next to impossible to even GUESS what that non factory wire is for.
Did you pull the ignition module that is right there off ? if someone with half a brain wired it then black would be a GROUND wire , was it under the bolt holding the module on since you think you have no spark ?
Re: What is this wire for? [Re: jayyohe] #2144556
08/31/16 01:49 PM
08/31/16 01:49 PM
get it good and hot. shut it off. pull & ground the coil wire or pull the ECU pentastar connector (work fast while it is still hot). Now see if it cranks
Re: What is this wire for? [Re: jayyohe] #2145343
09/01/16 01:12 PM
09/01/16 01:12 PM
Stinnett, Tx
rumblebee4232 Offline
Stinnett, Tx
So where are the before pictures??
