Aluminum driveshaft on the street, worth the cost??? #214349
02/04/09 10:16 PM
02/04/09 10:16 PM
Arkansas
340727dart Offline OP
Arkansas
I am just about done with the automatic to four-speed conversion in my Dart.
I called a local driveshaft shop today to check on costs. A steel driveshaft with new solid U-joints, and balanced, runs $225.
An aluminum driveshaft costs $325.
I understand that for racing purposes an aluminum driveshaft is more desirable because of the lower rotating weight. But, is the added cost really worth it on a 100% street driven car?
Your life is not my fault.
My life is none of your business.
Speech is free only if you agree with those in control.
Re: Aluminum driveshaft on the street, worth the cost??? [Re: 340727dart] #214350
02/04/09 10:19 PM
02/04/09 10:19 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
my dodge dakota has an aluminum shaft from the factory.
it's definitly a street driven vehicle! 4.7L quad cab, 2wd pick-up truck. fast, this truck is not!
**Photobucket sucks**
Re: Aluminum driveshaft on the street, worth the cost??? [Re: 70Cuda383] #214351
02/04/09 10:33 PM
02/04/09 10:33 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Remember that an aluminum shaft for the same HP is BIGGER in diameter. You can't stay at the same diameter alum vs steel...By the way, mine was over $800
Re: Aluminum driveshaft on the street, worth the cost??? [Re: 340727dart] #214352
02/04/09 11:01 PM
02/04/09 11:01 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Not unless you really, really, don't need the extra $100 for anything else.
Re: Aluminum driveshaft on the street, worth the cost??? [Re: slantzilla] #214353
02/05/09 01:31 AM
02/05/09 01:31 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
On my budget it was not worth it as I went with a mild steel shaft in my 63. So far i'ts been fine. Ron
Re: Aluminum driveshaft on the street, worth the cost??? [Re: 340727dart] #214354
02/05/09 02:38 AM
02/05/09 02:38 AM
I think it'd be similar to the weight reduction by going from an iron water pump or master cyl to an aluminum one(but more). It all adds up. With the compact mass of a driveshaft I dont think you would feel any gain from the decrease in rotating weight though
Re: Aluminum driveshaft on the street, worth the cost??? [Re: 340727dart] #214355
02/05/09 08:56 AM
02/05/09 08:56 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Nope...someone on the race board just did this swap. I think they lost 1 - 2 pounds, tops.
Re: Aluminum driveshaft on the street, worth the cost??? [Re: Sixpak] #214356
02/05/09 10:45 AM
02/05/09 10:45 AM
Dragula Offline
Dragula  Offline
Mine was 6lbs lighter, but again, so was my wallet!
I purchased the stainless yoke as well, and I put a forged one on the dana. I wanted it all bullet proof because when a drive shaft goes kaboom, so does your trans, floor boards, and sometimes the rear yoke and pinion...
Re: Aluminum driveshaft on the street, worth the cost??? [Re: Dragula] #214357
02/05/09 11:13 AM
02/05/09 11:13 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
There are many different levels of steel driveshaft and aluminum driveshaft in terms of quality. For example the top level of driveshaft for nitrous racing from Denny's driveshafts is a steel shaft.
On the street the quality is of less importance and but if can get an aluminum shaft for an extra $100 over a new steel. I'd do it, even for a driver.
If I already had perfectly good, functioning steel shaft. I would never bother to change it.
Re: Aluminum driveshaft on the street, worth the cost??? [Re: Magnum] #214358
02/05/09 08:59 PM
02/05/09 08:59 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Re: Aluminum driveshaft on the street, worth the cost??? [Re: 340727dart] #214359
02/05/09 09:08 PM
02/05/09 09:08 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
While you can measure the performance loss with a heavy shaft on the track(I have),the long term reliability of steel is the way to go for most apps. Strange Engineering has some good pricing on cromoly shafts if you want a potential upgrade.
Re: Aluminum driveshaft on the street, worth the cost?? [Re: goldmember] #214360
02/06/09 08:23 AM
02/06/09 08:23 AM
Q
Quicktree Offline
Quicktree  Offline
Q
there is 3-4#s difference in weight. anytime you can loose that much of rotating mass it's a plus imo. more than just the weight itself. call dynotech the 3.5" aluminum is very reasonable compared to the steel shafts. and it's only 1/4" bigger on each side.
Re: Aluminum driveshaft on the street, worth the cost?? [Re: Quicktree] #214361
02/06/09 08:09 PM
02/06/09 08:09 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I don't need a new shaft Qtree,mine is just fine.I also stated that yes you can measure the on track difference and I have.
Re: Aluminum driveshaft on the street, worth the cost??? [Re: 340727dart] #214362
02/08/09 10:26 PM
02/08/09 10:26 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
There are lots of oem driveshafts on Ebay. How bout a bargain unit with new ends welded on.
