Aluminum driveshaft on the street, worth the cost???
#214349
02/04/09 10:16 PM
02/04/09 10:16 PM
Posts: 8,144 Arkansas
340727dart
Arkansas
I am just about done with the automatic to four-speed conversion in my Dart. I called a local driveshaft shop today to check on costs. A steel driveshaft with new solid U-joints, and balanced, runs $225. An aluminum driveshaft costs $325. I understand that for racing purposes an aluminum driveshaft is more desirable because of the lower rotating weight. But, is the added cost really worth it on a 100% street driven car?
Your life is not my fault. My life is none of your business.
Speech is free only if you agree with those in control.
Re: Aluminum driveshaft on the street, worth the cost???
[Re: 340727dart]
#214350
02/04/09 10:19 PM
02/04/09 10:19 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
my dodge dakota has an aluminum shaft from the factory.
it's definitly a street driven vehicle! 4.7L quad cab, 2wd pick-up truck. fast, this truck is not!
**Photobucket sucks**
[Re: 340727dart]
#214355
02/05/09 08:56 AM
02/05/09 08:56 AM
Posts: 6,840 The Swamp
Sixpak
The Swamp
Nope...someone on the race board just did this swap. I think they lost 1 - 2 pounds, tops.
[Re: Sixpak]
#214356
02/05/09 10:45 AM
02/05/09 10:45 AM
Posts: 12,416 Taxes & Virus's R-US, NY
Dragula
Mine was 6lbs lighter, but again, so was my wallet!
I purchased the stainless yoke as well, and I put a forged one on the dana. I wanted it all bullet proof because when a drive shaft goes kaboom, so does your trans, floor boards, and sometimes the rear yoke and pinion...
[Re: Dragula]
#214357
02/05/09 11:13 AM
02/05/09 11:13 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
There are many different levels of steel driveshaft and aluminum driveshaft in terms of quality. For example the top level of driveshaft for nitrous racing from Denny's driveshafts is a steel shaft.
On the street the quality is of less importance and but if can get an aluminum shaft for an extra $100 over a new steel. I'd do it, even for a driver.
If I already had perfectly good, functioning steel shaft. I would never bother to change it.
[Re: Magnum]
#214358
02/05/09 08:59 PM
02/05/09 08:59 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
