Re: 440 dist gear
[Re: johnfin]
#2142719
08/28/16 09:31 PM
08/28/16 09:31 PM
Posts: 5,919 ohio
ruderunner
ohio
Remove oil pump and push the shaft out.
Might need able to twist it with a big screwdriver and use the cut of the gears to bring it up some.
Angry white pureblood male
Re: 440 dist gear
[Re: mopars4ever]
#2142760
08/28/16 10:19 PM
08/28/16 10:19 PM
RapidRobert
I have looped wire around it and just pulled up. that is what I do & you may have to have someone turn the crank at the same time (if cam/tchain is in)
