440 dist gear #2142687
08/28/16 08:44 PM
08/28/16 08:44 PM
gainsville, usa
johnfin Offline OP
johnfin  Offline OP
gainsville, usa
How can i pull the dist. Gear from an old engine?
Re: 440 dist gear [Re: johnfin] #2142719
08/28/16 09:31 PM
08/28/16 09:31 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Remove oil pump and push the shaft out.
Might need able to twist it with a big screwdriver and use the cut of the gears to bring it up some.
Angry white pureblood male
Re: 440 dist gear [Re: johnfin] #2142723
08/28/16 09:38 PM
08/28/16 09:38 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
I have looped wire around it and just pulled up.
Re: 440 dist gear [Re: johnfin] #2142750
08/28/16 10:10 PM
08/28/16 10:10 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
grab the slot with long nose needle nose pliers and twist it out.
Re: 440 dist gear [Re: mopars4ever] #2142760
08/28/16 10:19 PM
08/28/16 10:19 PM
that is what I do & you may have to have someone turn the crank at the same time (if cam/tchain is in)
Re: 440 dist gear [Re: johnfin] #2142854
08/29/16 12:32 AM
08/29/16 12:32 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
They can be hard to get out if a sludge buildup is on the shaft below the gear. I have one I cannot get out right now, and the frame is in the way of removing the oil pump and pounding it out. So this thread could help out.
Re: 440 dist gear [Re: johnfin] #2142857
08/29/16 12:34 AM
08/29/16 12:34 AM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
I didn't buy this with that in mind but I got one of these off the sale table at Tractor Supply. It works great on the distributor gear. Especially when you're trying to line up the slot.
Re: 440 dist gear [Re: johnfin] #2142936
08/29/16 04:49 AM
08/29/16 04:49 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
If the intake is off you can do it with a large screwdriver
