Re: help dana 60 posi or spool??????
[Re: hp340nos]
#2137562
08/21/16 12:06 AM
08/21/16 12:06 AM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
I just ordered a s60 from Dr Diff & he recommended the Strange s trac it has the helical cut gears inside, he said it is very strong & works very well.
the eaton true trac for an 83/4 is junk
[Re: CSK]
#2137653
08/21/16 02:44 AM
08/21/16 02:44 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
the eaton true trac for an 83/4 is junk Years ago I found on E-bay a Gleason Torsen differential for the Dana 60 that I had in my '64 Polara. I had toasted a TracLok rear. Fortunately it came with the 30 spline spiders and was for a 3.54 gear so it was a near bolt in. This was the forerunner of the new helical cut gear diffs and was near invisible in operation. Used regular gear oil and no additive, too. This is best for the street...believe in the good doctor he is right, spools are for the drag strip.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: hp340nos]
#2138166
08/21/16 09:40 PM
08/21/16 09:40 PM
Posts: 11,726 Portage,michigan
B3422W5
Portage,michigan
Spool.
Never had one make the car get out of shape getting out of the gas on the street. But the one and only Detroit Locker I had sure was squirrelly. Never again Spool is the way to go.
[Re: Tempest]
#2138204
08/21/16 10:57 PM
08/21/16 10:57 PM
B3422W5
Portage,michigan
At the time, Ma Mopar was making motors (race HEMI's) with 600 HP max. Technology has come along way. People today run much bigger, higher HP/TQ motors, nitrous, turbos etc. A posi will not stand that kind of power.
Exactly
[Re: hp340nos]
#2138248
08/21/16 11:33 PM
08/21/16 11:33 PM
Posts: 8,182 Plymouth, MI
Blusmbl
Plymouth, MI
You're going to get varying opinions on this, but something like a Detroit locker is safer if you get caught in the rain on slicks. Drag radials aren't as bad, but if you're on something with timy or no rain grooves having an open diff when you're off the throttle is a little safer. I had some close calls on worn out Quick Time Pros.
On dry pavement I wouldn't worry about either choice.
[Re: 6pakdakota]
#2138319
08/22/16 01:16 AM
08/22/16 01:16 AM
Posts: 4,702 Wichita
GY3
Wichita
I just went through this after my Auburn unit gave up after less than 2000 miles on the street in my 8 3/4.
600 hp and sticky tires are hard on parts. I went with a spool in the Dana and, while it's harder to go around corners, it was worth it IMO.
[Re: hp340nos]
#2138322
08/22/16 01:26 AM
08/22/16 01:26 AM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
I went with a posi unit in my Dana 60. No complaints so far. Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: hp340nos]
#2138323
08/22/16 01:27 AM
08/22/16 01:27 AM
Posts: 205 Edmonton Alberta, Canada
R3DART
I just recently swapped out my 8 3/4 with spool for a Dana 60 with a Detroit locker. I had zero issues with driving the spool on the street. Did not find it hard to park, never had any problems when backing out of it on highway as suggested, and even in the little bit of wet weather driving I did, with the drag radials it was nothing that I felt uncomfortable with at all. The Dana with the Detroit locker (in the car now) is fine. I do not mind it at all. Definitely more clunking and banging goes on but not bad in my opinion. That said, the next diff I build will have a spool in it again. Nice and simple. Quite a few years back I had an 84 chev short box 4x4. I had a spool in it with 44" super swampers on it. I didn't mind it at all on the street either so maybe I'm just willing to put up with more than some!!
