help dana 60 posi or spool?????? #2137510
08/20/16 10:11 PM
08/20/16 10:11 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
not sure to go posi or spool at this time .i twisted an axle on the 8 3/4 and will building the dana,i already have a dana 60 hd narrowed with mosier ends and perches done in a jig.88 dakota street/strip 340 stroker 470 hp on motor plus a 100 hp shot of nitrous truck weighs 3400. i run drag radials.best et 6.77@101 with a 1.48 60ft.this is a street driven to the track.not a daily driver.i know if will push little turning etc,but is it really that bad with a spool?
Re: help dana 60 posi or spool?????? [Re: hp340nos] #2137514
08/20/16 10:27 PM
08/20/16 10:27 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
You'll find out real fast how bad it is on the first wet day you end up in. A good quality posi unit will be fine for street/strip.
[image][/image]
Re: help dana 60 posi or spool?????? [Re: hp340nos] #2137516
08/20/16 10:33 PM
08/20/16 10:33 PM
Nashville, Tennessee
Tempest Offline
Tempest  Offline
8 3/4 posi with the right parts will live to 600 HP wit slicks for a while. A Dana even more. I ran a spool for years on a street/strip car. Car was only driven on dry pavement. Parking can be a PITA, however.
Re: help dana 60 posi or spool?????? [Re: Tempest] #2137548
08/20/16 11:49 PM
08/20/16 11:49 PM
birdtracker Offline
birdtracker  Offline
Posi is the only way to go. With a spool even letting off it at high speeds on the street you will notice it moving around. Birdtracker
Re: help dana 60 posi or spool?????? [Re: hp340nos] #2137562
08/21/16 12:06 AM
08/21/16 12:06 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I just ordered a s60 from Dr Diff & he recommended the Strange s trac it has the helical cut gears inside, he said it is very strong & works very well.
the eaton true trac for an 83/4 is junk
Re: help dana 60 posi or spool?????? [Re: CSK] #2137653
08/21/16 02:44 AM
08/21/16 02:44 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Years ago I found on E-bay a Gleason Torsen differential for the Dana 60 that I had in my '64 Polara. I had toasted a TracLok rear. Fortunately it came with the 30 spline spiders and was for a 3.54 gear so it was a near bolt in. This was the forerunner of the new helical cut gear diffs and was near invisible in operation. Used regular gear oil and no additive, too. This is best for the street...believe in the good doctor he is right, spools are for the drag strip.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: help dana 60 posi or spool?????? [Re: hp340nos] #2137654
08/21/16 02:46 AM
08/21/16 02:46 AM
On your deal I would put a good lightweight spool in it thumbs twocentsI driven cars with posi and spools on the street with some HP, any one can get either one out of shape if they want to shruggy The spool will save you a bunch of weight compared to a clutch type Dana 60 posi, which should make the truck quicker and faster shruggywork
Re: help dana 60 posi or spool?????? [Re: hp340nos] #2138006
08/21/16 04:59 PM
08/21/16 04:59 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Go with a sure grip....
Nautilus Racing-
Re: help dana 60 posi or spool?????? [Re: hp340nos] #2138045
08/21/16 06:02 PM
08/21/16 06:02 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Spool and be done with it...
Re: help dana 60 posi or spool?????? [Re: hp340nos] #2138096
08/21/16 07:44 PM
08/21/16 07:44 PM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
spool it
Re: help dana 60 posi or spool?????? [Re: hp340nos] #2138166
08/21/16 09:40 PM
08/21/16 09:40 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Spool.
Never had one make the car get out of shape getting out of the gas on the street.
But the one and only Detroit Locker I had sure was squirrelly. Never again
Spool is the way to go.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: help dana 60 posi or spool?????? [Re: hp340nos] #2138185
08/21/16 10:16 PM
08/21/16 10:16 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I vote for spool also..
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: help dana 60 posi or spool?????? [Re: hp340nos] #2138197
08/21/16 10:48 PM
08/21/16 10:48 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I guess Chrysler was real dumb for putting trac-loks in the their Dana rears.
Re: help dana 60 posi or spool?????? [Re: cudaman1969] #2138202
08/21/16 10:52 PM
08/21/16 10:52 PM
Tempest Offline
Tempest  Offline
At the time, Ma Mopar was making motors (race HEMI's) with 600 HP max. Technology has come along way. People today run much bigger, higher HP/TQ motors, nitrous, turbos etc. A posi will not stand that kind of power.
Re: help dana 60 posi or spool?????? [Re: Tempest] #2138204
08/21/16 10:57 PM
08/21/16 10:57 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Exactly
1.41 best 60 foot
6.56 at 104.17
Re: help dana 60 posi or spool?????? [Re: hp340nos] #2138248
08/21/16 11:33 PM
08/21/16 11:33 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
You're going to get varying opinions on this, but something like a Detroit locker is safer if you get caught in the rain on slicks. Drag radials aren't as bad, but if you're on something with timy or no rain grooves having an open diff when you're off the throttle is a little safer. I had some close calls on worn out Quick Time Pros.
On dry pavement I wouldn't worry about either choice.
Re: help dana 60 posi or spool?????? [Re: hp340nos] #2138281
08/22/16 12:09 AM
08/22/16 12:09 AM
michigan
6pakdakota Offline
6pakdakota  Offline
michigan
Go with a spool. I had one in my daily driver dakota with drag radials for years. The only time it ever got sketchy was when the tires were bald in the rain.
Re: help dana 60 posi or spool?????? [Re: 6pakdakota] #2138319
08/22/16 01:16 AM
08/22/16 01:16 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I just went through this after my Auburn unit gave up after less than 2000 miles on the street in my 8 3/4.
600 hp and sticky tires are hard on parts. I went with a spool in the Dana and, while it's harder to go around corners, it was worth it IMO.
'63 Dodge 330
11.19 @ 121 mph
Re: help dana 60 posi or spool?????? [Re: hp340nos] #2138322
08/22/16 01:26 AM
08/22/16 01:26 AM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I went with a posi unit in my Dana 60. No complaints so far.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: help dana 60 posi or spool?????? [Re: hp340nos] #2138323
08/22/16 01:27 AM
08/22/16 01:27 AM
Edmonton Alberta, Canada
R3DART Offline
R3DART  Offline
I just recently swapped out my 8 3/4 with spool for a Dana 60 with a Detroit locker.
I had zero issues with driving the spool on the street. Did not find it hard to park, never had any problems when backing out of it on highway as suggested, and even in the little bit of wet weather driving I did, with the drag radials it was nothing that I felt uncomfortable with at all.
The Dana with the Detroit locker (in the car now) is fine. I do not mind it at all. Definitely more clunking and banging goes on but not bad in my opinion.
That said, the next diff I build will have a spool in it again. Nice and simple.
Quite a few years back I had an 84 chev short box 4x4. I had a spool in it with 44" super swampers on it. I didn't mind it at all on the street either so maybe I'm just willing to put up with more than some!!
