Tubes or no tubes? #213692
02/04/09 10:25 AM
02/04/09 10:25 AM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
I'm looking at buying my first set of slicks to run in street and sportsman class. So they must be D.O.T approved. Which way should I go tubes or not? Whats the pros and cons of each. They will be going on a 67 Coronet BB with a 727 and SS springs
Re: Tubes or no tubes? [Re: flatiron] #213693
02/04/09 10:33 AM
02/04/09 10:33 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
I haven't used tubes in any tires in years. My present racer is an Outlaw 10.5 car. We use 33/10.5W-16 tires on 16" wide double beedlocks. Car has run in the 6's at 206. No tubes. Nobody that races with us uses tubes. For bracket racing there is less of a reason to not use them.
Re: Tubes or no tubes? [Re: flatiron] #213694
02/04/09 10:52 AM
02/04/09 10:52 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I've never played with a DOT tire but in my car I've
run with and without tubes. With the tubes it gave me
a stiffer side wall and increased the life of the
side walls by a good 40%-50% more runs. When I get
rid of my tires there's plenty of rubber left but the
sides are going away
Re: Tubes or no tubes? [Re: MR_P_BODY] #213695
02/04/09 11:01 AM
02/04/09 11:01 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
I run tubes in mine, for the stiffer side wall, and not having to worry about leaking air
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Tubes or no tubes? [Re: BloFish] #213696
02/04/09 11:29 AM
02/04/09 11:29 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
No tubes, No screws, I'm a rebel
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Tubes or no tubes? [Re: BloFish] #213697
02/04/09 11:39 AM
02/04/09 11:39 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
The downsides are that you have to screw the rim or you could pull the valve out if the bead slips-this has caused some serious issues over the years, the extra weight costs some ET and the tubes will not allow the tire to lay perfectly flat. If you are bracket racing the last 3 hundredths don't really matter so extra tire life may be a reason to use them. Don't forget that good tubes cost over a hundred bucks apiece.
Re: Tubes or no tubes? [Re: BobR] #213698
02/04/09 01:30 PM
02/04/09 01:30 PM
Keymar, MD
DusterKid Online content
DusterKid  Online Content
Keymar, MD
Tubes...dont' have to worry about air leaking out, and helps make the sidewalls of the tires last longer.
Re: Tubes or no tubes? [Re: BobR] #213699
02/04/09 01:36 PM
02/04/09 01:36 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
I think this statement summs it up beadlocks for fast cars.Tubes for us slow guys
Re: Tubes or no tubes? [Re: DusterKid] #213700
02/04/09 02:20 PM
02/04/09 02:20 PM
mikemotorhead Offline
super street
super street
"Tubes...dont' have to worry about air leaking out, and helps make the sidewalls of the tires last longer. "
Re: Tubes or no tubes? [Re: mikemotorhead] #213701
02/04/09 03:48 PM
02/04/09 03:48 PM
Riverside, California
Lil Demon Offline
Lil Demon  Offline
2 Tubes + 2 Tires = 4 things that can potentially go wrong at the track.
0 Tubes + 2 Tires = 2 things that can potentially go wrong at the track.
Rip a tube and you are done. Get a small hole in a tire - plug it and keep going.
No tubes = less rotating weight and less $ spent
Tubes = stiffer sidewall - but I can order tires with that already built in.
Re: Tubes or no tubes? [Re: Lil Demon] #213702
02/04/09 04:25 PM
02/04/09 04:25 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
One of the things that made me wonder about this is looking at the Tire discription's in the Summit
catalog almost all the slicks call for a tube. Iwas really suprised all the more tire choices non-tube guys have. So my next question is can you take a tire that calls for a tube and use it without one?
Re: Tubes or no tubes? [Re: flatiron] #213703
02/04/09 04:55 PM
02/04/09 04:55 PM
Lil Demon Offline
Lil Demon  Offline
Yep - Dawn dish soap and some rim screws.
Re: Tubes or no tubes? [Re: Lil Demon] #213704
02/04/09 06:11 PM
02/04/09 06:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I ordered stiff sidewall tires 1 time.... they were way
too stiff... Tubes arent for everyone but I'll stick
with them till I change something and dont need them.
Screws and slicks are a must to me, I cant believe
Bigdad doesnt run screws. I've seen cars get out of
shape without screws and low tire pressure and it
pushed the tire off the bead... to each his own
Re: Tubes or no tubes? [Re: MR_P_BODY] #213705
02/04/09 06:18 PM
02/04/09 06:18 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
If I worried about that, I'd have to screw the front tires to the rims too
Re: Tubes or no tubes? [Re: bigdad] #213706
02/04/09 06:27 PM
02/04/09 06:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont know about you but I run 45 psi in my fronts
but low pressure in the rears(6.75 psi)and with the
low pressure there isnt alot to hold them on... but
like I said.... to each his own
Re: Tubes or no tubes? [Re: bigdad] #213707
02/04/09 06:38 PM
02/04/09 06:38 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Buy the new slicks, soap them up and run them until you start having to pump them up more than you would like. Then if you still have tread left put in the tubes. Some guy's change there slicks more than they change their underwear, some change them after they start to rot.
Re: Tubes or no tubes? [Re: BobR] #213708
02/04/09 06:57 PM
02/04/09 06:57 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Yep.
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Tubes or no tubes? [Re: Lil Demon] #213709
02/04/09 07:05 PM
02/04/09 07:05 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
ever see a tube get wadded up in the tire?
Re: Tubes or no tubes? [Re: dthemi] #213710
02/04/09 07:18 PM
02/04/09 07:18 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Nope
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Tubes or no tubes? [Re: dthemi] #213711
02/04/09 07:22 PM
02/04/09 07:22 PM
rowin4 Offline
rowin4  Offline
If installed correctly they won't wad up, every one i have changed out never had a wrinkle in them. If installed correctly , having the tire desoaped, is that a word? [ cleaned and dry ] then use lots of tire talc to keep the tube from binding you'll have no problem.
