Running out of fuel street HEMI #2136081
08/18/16 07:02 PM
08/18/16 07:02 PM
MN
36viper Offline OP
36viper  Offline OP
MN
Hi guys!
I have always had an apparent fuel delivery problem in my '68 HEMI Charger. On hard acceleration from slow roll or stop, it begins to pop and loose power around 80mph.. It pulls really hard if one is just cruising around in 4th gear and steps on the throttle. Its also really strong up to 80 mph when accelerating hard. After experiencing the problem, I installed a high output fuel pump, but it still didn't cure the issue.
The 426 HEMI has a moderate build and requires 50% race gas.
Someone told me that I should put a fuel flow restrictor in the return line to the tank, that is designed to prevent vapor lock, that the carbs would get more fuel and wouldn't run low on sustained acceleration. He said I should drill a certain sized hole into a bolt, and insert in into the 3/8" line to reduce the amount of gas that's returning to the tank. I'm thinking of putting a vice grip on the return line, to see if it solves the problem, then I'll make a restrictor for the return line if the vice grip solves the problem.
The fuel gauge just quit working, so I'll check the filter on the end of the pick-up line when I'm working on the sending unit. Maybe it's plugged, or maybe there is an air leak in the fuel line somewhere???
Thank you Moparts for the help!
Re: Running out of fuel street HEMI [Re: 36viper] #2136088
08/18/16 07:12 PM
08/18/16 07:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Is it a mech pump or electric... what carbs..
what size needle/seat.. have you done a flow
check(gals per minute).. do you still have the
stock sock on the pick up... do the filters have
enough flow... thats a start
wave
Re: Running out of fuel street HEMI [Re: 36viper] #2136234
08/18/16 10:54 PM
08/18/16 10:54 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
Check the fuel pump pushrod to see if it is worn. If it is, it won't give the pump a full stroke.
Re: Running out of fuel street HEMI [Re: 469runner] #2136308
08/19/16 12:01 AM
08/19/16 12:01 AM
MN
36viper Offline OP
36viper  Offline OP
MN
It's a new high output mechanical fuel pump. It didn't seem to help with the supply problem. I'll check the sock this week.
Re: Running out of fuel street HEMI [Re: MR_P_BODY] #2136310
08/19/16 12:04 AM
08/19/16 12:04 AM
MN
36viper Offline OP
36viper  Offline OP
MN
Factory carbs and jetting, new mechanical pump.
Re: Running out of fuel street HEMI [Re: 36viper] #2136314
08/19/16 12:10 AM
08/19/16 12:10 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
From reg to carb you want 6-7 psi running, having a gauge set up so you can see it when the problems start will tell you. Is your fuel pressure dropping off ?
1963 Plymouth Max Wedge
1971 Barracuda
Re: Running out of fuel street HEMI [Re: 36viper] #2136323
08/19/16 12:23 AM
08/19/16 12:23 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I struggled with a high output mechanical pump on my 440. I consider myself pretty competent and I gave up. Went electric.
Did a bunch of testing and tried a couple of pumps. All were Carter.
Re: Running out of fuel street HEMI [Re: ozymaxwedge] #2136344
08/19/16 12:45 AM
08/19/16 12:45 AM
iagree
To fix the problems you need to know first what they are scopeI use to race two non original street Hemi cars in NHRA stock back in the early to mid 1970s. Both had 5/16 lines and pickups, both needed the Carter 3 valve race Hemi H.P. NASCAR type pumps to run with enough fuel supply shruggy scope
Good luck, let us know what you find and do to fix that problem thumbs
Re: Running out of fuel street HEMI [Re: 36viper] #2136481
08/19/16 10:17 AM
08/19/16 10:17 AM
an8sec70cuda Offline
Get rid of the sock filter in the tank.
Remove and measure the length of the fuel pump pushrod to make sure it isn't worn.
You should be able to eliminate the return line.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Running out of fuel street HEMI [Re: an8sec70cuda] #2136675
08/19/16 03:33 PM
08/19/16 03:33 PM
Wasn't the special OEM fuel filter used on the original cars suppose to be a vapor seperator? Not for liquid returns is what I remember work
Re: Running out of fuel street HEMI [Re: 36viper] #2136714
08/19/16 04:44 PM
08/19/16 04:44 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the aftermarket vapor seperaters have too large of a return orifice. i solder the hole up and re-drill to .046". not all aftermarket "high performance" mechanical pumps are equal.
Re: Running out of fuel street HEMI [Re: lewtot184] #2136720
08/19/16 05:02 PM
08/19/16 05:02 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Mechanical heat sinking pumps = down
Re: Running out of fuel street HEMI [Re: Thumperdart] #2136746
08/19/16 06:07 PM
08/19/16 06:07 PM
X3, see what you have AT the carbs at the offending RPM/load with an accurate gauge on the cowl or plumbed inside (just for the test of course! or with an isolator for safety)
Re: Running out of fuel street HEMI [Re: Cab_Burge] #2136910
08/19/16 10:40 PM
08/19/16 10:40 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I never heard of a return line to the tank, vapor can like Cab said, could be broke and just circling back to pump. Hemi cars came with 3/8 line. That stock pump "should" pump enough fuel for the carbs, cover the lines from heat to stop vapor lock. My two cents.
Re: Running out of fuel street HEMI [Re: cudaman1969] #2136915
08/19/16 10:48 PM
08/19/16 10:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The sock in the tank will separate water until
its totally under water.. but its not 100%..
the return just has a orifice.. pretty sure back
then it was .060
EDIT
Yes they did have a return to the tank... any of
the so called performance engines had a return..
any that had a 3/8 supply had a return
wave
Re: Running out of fuel street HEMI [Re: MR_P_BODY] #2136986
08/20/16 12:37 AM
08/20/16 12:37 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
U
then it was .060
EDIT
wave
Return line or vent line? How big a performance engine did it have to be? My a-body m-code 440 only has one 3/8 line, maybe because it started as a 383?
Re: Running out of fuel street HEMI [Re: cudaman1969] #2137037
08/20/16 01:31 AM
08/20/16 01:31 AM
MR_P_BODY Offline
MR_P_BODY  Offline
U
then it was .060
EDIT
wave
If t was factory and labeled HP it had 3/8 supply
and a 1/4 return and a 1/4 vent... a 3 tube bundle
clamped together in the 70s with the charcoal canister
up front.. otherwise it had the vent in the frame rail
on older years but still had the 3/8 and 1/4 going forward
if it went into the fame rail it was likely a 3/16 vent
wave
Re: Running out of fuel street HEMI [Re: 36viper] #2137666
08/21/16 04:24 AM
08/21/16 04:24 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Some of the Mopars had the 3 tube fuel filters which many called a vapor seperator. The third line did go back to the fuel tank but it was not for fuel flow like a fuel pressure regulator can use it was a vapor return line as it had a small orifice somewhere around .050 to let fuel vapors escape out of the fuel line/filter and route it back to the tank. A small amount of fuel could also go back to the tank along with the vapor but the orifice was small enough that only a very small amount of fuel could get through the orifice which was not enough to cause a fuel pressure loss but letting the fuel vapors escape helped the car run better. Ron
Re: Running out of fuel street HEMI [Re: 36viper] #2137690
08/21/16 09:01 AM
08/21/16 09:01 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
I had a pretty new carter crap the bed. So have many others. I dont think the quality is there with their mechanical pumps. If all else checks out, try a holley pump.
Re: Running out of fuel street HEMI [Re: Hot 340] #2137711
08/21/16 09:51 AM
08/21/16 09:51 AM
Hamburg, Pa.
72 RR DUDE Offline
72 RR DUDE  Offline
Hamburg, Pa.
Have a 72 RR that I restored about 5 years ago and put a 440 + 6 in the car and the engine was mildly build but it couldn't even spin the tires.Have a 3/8 fuel line and the vapor line to the front. After checking everything possible after all the searching I stumbled on to the problem about a month ago. I didn't have a vented gas cap on the car and had created a closed system. I drilled a small hole in the center of the cap and the car run's like a house on fire! P.S. I couldn't find a vented cap they are hard to find thus the hole in the cap!
