Running out of fuel street HEMI
#2136081
08/18/16 07:02 PM
08/18/16 07:02 PM
Posts: 36 MN
36viper
MN
Hi guys! I have always had an apparent fuel delivery problem in my '68 HEMI Charger. On hard acceleration from slow roll or stop, it begins to pop and loose power around 80mph.. It pulls really hard if one is just cruising around in 4th gear and steps on the throttle. Its also really strong up to 80 mph when accelerating hard. After experiencing the problem, I installed a high output fuel pump, but it still didn't cure the issue. The 426 HEMI has a moderate build and requires 50% race gas. Someone told me that I should put a fuel flow restrictor in the return line to the tank, that is designed to prevent vapor lock, that the carbs would get more fuel and wouldn't run low on sustained acceleration. He said I should drill a certain sized hole into a bolt, and insert in into the 3/8" line to reduce the amount of gas that's returning to the tank. I'm thinking of putting a vice grip on the return line, to see if it solves the problem, then I'll make a restrictor for the return line if the vice grip solves the problem. The fuel gauge just quit working, so I'll check the filter on the end of the pick-up line when I'm working on the sending unit. Maybe it's plugged, or maybe there is an air leak in the fuel line somewhere???
Thank you Moparts for the help!
Re: Running out of fuel street HEMI
[Re: 36viper]
#2136088
08/18/16 07:12 PM
08/18/16 07:12 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Is it a mech pump or electric... what carbs.. what size needle/seat.. have you done a flow check(gals per minute).. do you still have the stock sock on the pick up... do the filters have enough flow... thats a start
[Re: 469runner]
#2136308
08/19/16 12:01 AM
08/19/16 12:01 AM
Posts: 36 MN
36viper
MN
It's a new high output mechanical fuel pump. It didn't seem to help with the supply problem. I'll check the sock this week.
[Re: MR_P_BODY]
#2136310
08/19/16 12:04 AM
08/19/16 12:04 AM
Posts: 36 MN
36viper
MN
Factory carbs and jetting, new mechanical pump.
[Re: 36viper]
#2136314
08/19/16 12:10 AM
08/19/16 12:10 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
From reg to carb you want 6-7 psi running, having a gauge set up so you can see it when the problems start will tell you. Is your fuel pressure dropping off ?
1963 Plymouth Max Wedge 1971 Barracuda
[Re: 36viper]
#2136323
08/19/16 12:23 AM
08/19/16 12:23 AM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
I struggled with a high output mechanical pump on my 440. I consider myself pretty competent and I gave up. Went electric.
Did a bunch of testing and tried a couple of pumps. All were Carter.
[Re: ozymaxwedge]
#2136344
08/19/16 12:45 AM
08/19/16 12:45 AM
Posts: 43,190 Bend,OR USA
Cab_Burge
To fix the problems you need to know first what they are I use to race two non original street Hemi cars in NHRA stock back in the early to mid 1970s. Both had 5/16 lines and pickups, both needed the Carter 3 valve race Hemi H.P. NASCAR type pumps to run with enough fuel supply Good luck, let us know what you find and do to fix that problem
[Re: 36viper]
#2136481
08/19/16 10:17 AM
08/19/16 10:17 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
Get rid of the sock filter in the tank.
Remove and measure the length of the fuel pump pushrod to make sure it isn't worn.
You should be able to eliminate the return line.
[Re: Thumperdart]
#2136746
08/19/16 06:07 PM
08/19/16 06:07 PM
RapidRobert
X3, see what you have AT the carbs at the offending RPM/load with an accurate gauge on the cowl or plumbed inside (just for the test of course! or with an isolator for safety)
[Re: cudaman1969]
#2136915
08/19/16 10:48 PM
08/19/16 10:48 PM
MR_P_BODY
Wasn't the special OEM fuel filter used on the original cars suppose to be a vapor seperator? Not for liquid returns is what I remember I never heard of a return line to the tank, vapor can like Cab said, could be broke and just circling back to pump. Hemi cars came with 3/8 line. That stock pump "should" pump enough fuel for the carbs, cover the lines from heat to stop vapor lock. My two cents. The sock in the tank will separate water until its totally under water.. but its not 100%.. the return just has a orifice.. pretty sure back then it was .060 EDIT Yes they did have a return to the tank... any of the so called performance engines had a return.. any that had a 3/8 supply had a return
[Re: MR_P_BODY]
#2136986
08/20/16 12:37 AM
08/20/16 12:37 AM
Posts: 8,270 fredericksburg,va
cudaman1969
fredericksburg,va
U Wasn't the special OEM fuel filter used on the original cars suppose to be a vapor seperator? Not for liquid returns is what I remember I never heard of a return line to the tank, vapor can like Cab said, could be broke and just circling back to pump. Hemi cars came with 3/8 line. That stock pump "should" pump enough fuel for the carbs, cover the lines from heat to stop vapor lock. My two cents. The sock in the tank will separate water until its totally under water.. but its not 100%.. the return just has a orifice.. pretty sure back then it was .060 EDIT Yes they did have a return to the tank... any of the so called performance engines had a return.. any that had a 3/8 supply had a return Return line or vent line? How big a performance engine did it have to be? My a-body m-code 440 only has one 3/8 line, maybe because it started as a 383?
[Re: cudaman1969]
#2137037
08/20/16 01:31 AM
08/20/16 01:31 AM
MR_P_BODY
U Wasn't the special OEM fuel filter used on the original cars suppose to be a vapor seperator? Not for liquid returns is what I remember I never heard of a return line to the tank, vapor can like Cab said, could be broke and just circling back to pump. Hemi cars came with 3/8 line. That stock pump "should" pump enough fuel for the carbs, cover the lines from heat to stop vapor lock. My two cents. The sock in the tank will separate water until its totally under water.. but its not 100%.. the return just has a orifice.. pretty sure back then it was .060 EDIT Yes they did have a return to the tank... any of the so called performance engines had a return.. any that had a 3/8 supply had a return Return line or vent line? How big a performance engine did it have to be? My a-body m-code 440 only has one 3/8 line, maybe because it started as a 383? If t was factory and labeled HP it had 3/8 supply and a 1/4 return and a 1/4 vent... a 3 tube bundle clamped together in the 70s with the charcoal canister up front.. otherwise it had the vent in the frame rail on older years but still had the 3/8 and 1/4 going forward if it went into the fame rail it was likely a 3/16 vent
