ANY New S.B good piston stroke kit #212747
02/03/09 11:23 AM
02/03/09 11:23 AM
St. Louis Mo.
10 o to go Offline OP
"Happy Don"
"Happy Don"
St. Louis Mo.
When i built my stroker 6 yrs ago went with 4" ohio cast crank limited valve reliefs, compression kieth black .Has to be a better p/v piston Motor is deceased now .
So who sells a complete 4"steel short block or a 4"steel crank kit .
The combo my heads are eddies stamped 6077 with ferra 2.08 intakes milled .050.
Who makes a kit to get compression up but have reliefs to handle up to 600 lift.
I see alot of 408 looking at 410 to 418 ci
trying to get ideas before going to indy swap meet .
thanks don
looking for 9.90 et now
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: ANY New S.B good piston stroke kit [Re: 10 o to go] #212748
02/03/09 11:27 AM
02/03/09 11:27 AM
Q
Quicktree Offline
Quicktree  Offline
Q
check with Dram
Re: ANY New S.B good piston stroke kit [Re: 10 o to go] #212749
02/03/09 11:34 AM
02/03/09 11:34 AM
St. Louis Mo.
"Happy Don"
"Happy Don"
St. Louis Mo.
thanks tony.
time and money are both colliding .Really like to just drop a bullet in.If i dont get one in soon they are going to make me put in a big block goes against my dumb 32 years of racing .
don
Re: ANY New S.B good piston stroke kit [Re: 10 o to go] #212750
02/03/09 12:05 PM
02/03/09 12:05 PM
O'Fallon,IL.
70RTRacer Offline
70RTRacer  Offline
O'Fallon,IL.
Don,
If you try a big block you wont go back.
Re: ANY New S.B good piston stroke kit [Re: Quicktree] #212751
02/03/09 01:51 PM
02/03/09 01:51 PM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
check with Dram
I just got a kit from him for a 340 block and he made me a great deal on it. K1 crank and rods, Diamond custom pistons.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: ANY New S.B good piston stroke kit [Re: 10 o to go] #212752
02/03/09 02:40 PM
02/03/09 02:40 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
didnt you toss a rod at the monster last year? i think I have a picture of that rods with piece of crank attached to it on my computer
Re: ANY New S.B good piston stroke kit [Re: aarcuda] #212753
02/03/09 03:02 PM
02/03/09 03:02 PM
St. Louis Mo.
"Happy Don"
"Happy Don"
St. Louis Mo.
not all really, crank became 3 pcs scored block hard .But i pushed that motor for about 6 years on alky also .steel crank next.
thanks don
Re: ANY New S.B good piston stroke kit [Re: 10 o to go] #212754
02/03/09 11:23 PM
02/03/09 11:23 PM
Wisconsin
wkroncke17 Offline
wkroncke17  Offline
Wisconsin
Hughes makes the 426 small block stroker kit that I would love to buy soon. It sounds like a real torqe monster.
Check their website, they have alot of tech articles - good reading.
Re: ANY New S.B good piston stroke kit [Re: 10 o to go] #212755
02/04/09 03:51 AM
02/04/09 03:51 AM
San Diego
formula S Offline
formula S  Offline
San Diego
Here are some small block kits http://www.gofaststuff.com/kits.html
Re: ANY New S.B good piston stroke kit [Re: 10 o to go] #212756
02/04/09 10:58 AM
02/04/09 10:58 AM
Don, you got all that out of a cast crank??!!! WOW how high did you twist that? Mike
