When i built my stroker 6 yrs ago went with 4" ohio cast crank limited valve reliefs, compression kieth black .Has to be a better p/v piston Motor is deceased now .
So who sells a complete 4"steel short block or a 4"steel crank kit .
The combo my heads are eddies stamped 6077 with ferra 2.08 intakes milled .050.
Who makes a kit to get compression up but have reliefs to handle up to 600 lift.
I see alot of 408 looking at 410 to 418 ci
trying to get ideas before going to indy swap meet .
thanks don
looking for 9.90 et now
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
