Re: upgrading cam to a solid lifter
[Re: moparpro]
#2126876
08/07/16 01:02 AM
08/07/16 01:02 AM
Posts: 863 Pinelands , NJ
joelson6
Pinelands , NJ
unless you were having problems with the existing bearings, i would just swap the cam, I have done it before.
or,
if the cam manufacture recommends a specific bearing, then i would swap the bearings.
[Re: joelson6]
#2126929
08/07/16 02:27 AM
08/07/16 02:27 AM
RapidRobert
you are pulling the eng correct? I would install new cam bearings. they are a major oil leak and anything you can do to reduce that is good including reducing the oil to them (if this is a low po DD then I can see leaving them alone). you would have to borrow the driver or pay your shop to do em
[Re: moparpro]
#2127054
08/07/16 12:01 PM
08/07/16 12:01 PM
Posts: 12,078 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
A rev limiter.
I had run hydraulics for many, many years before I ran my first solid and had never had a rev limiter. Since I had never had a problem, I didn't think that I needed one.
Without going into all the details, the solid will rev so much higher (whether you mean it to or not) that I believe a rev limiter is a must.
Master, again and still
[Re: moparpro]
#2127090
08/07/16 01:09 PM
08/07/16 01:09 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
New push rods.Even if you have adjustables now the rods will be too short.Rocky
Chrysler Firepower
[Re: moparpro]
#2127099
08/07/16 01:21 PM
08/07/16 01:21 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I don't change cam bearings unless they are bad or the engine block is going to be hot tanked.
