upgrading cam to a solid lifter #2126832
08/06/16 11:56 PM
08/06/16 11:56 PM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
TAKING ENG OUT,SHOULD I REPLACE CAM BEARINGS?I KNOW NEW SPRINGS AND LIFTERS ARE REQUIRED,ANYTHING ELSE I SHOULD REDO FOR NEW CAM?
Re: upgrading cam to a solid lifter [Re: moparpro] #2126876
08/07/16 01:02 AM
08/07/16 01:02 AM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
unless you were having problems with the existing bearings, i would just swap the cam, I have done it before.
or,
if the cam manufacture recommends a specific bearing, then i would swap the bearings.
Re: upgrading cam to a solid lifter [Re: joelson6] #2126929
08/07/16 02:27 AM
08/07/16 02:27 AM
you are pulling the eng correct? I would install new cam bearings. they are a major oil leak and anything you can do to reduce that is good including reducing the oil to them (if this is a low po DD then I can see leaving them alone). you would have to borrow the driver or pay your shop to do em
Re: upgrading cam to a solid lifter [Re: moparpro] #2127054
08/07/16 12:01 PM
08/07/16 12:01 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
A rev limiter.
I had run hydraulics for many, many years before I ran my first solid and had never had a rev limiter. Since I had never had a problem, I didn't think that I needed one.
Without going into all the details, the solid will rev so much higher (whether you mean it to or not) that I believe a rev limiter is a must.
Master, again and still
Re: upgrading cam to a solid lifter [Re: moparpro] #2127090
08/07/16 01:09 PM
08/07/16 01:09 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
New push rods.Even if you have adjustables now the rods will be too short.Rocky
Chrysler Firepower
Re: upgrading cam to a solid lifter [Re: moparpro] #2127099
08/07/16 01:21 PM
08/07/16 01:21 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I don't change cam bearings unless they are bad or the engine block is going to be hot tanked.
Nautilus Racing-
Re: upgrading cam to a solid lifter [Re: moparpro] #2127144
08/07/16 02:30 PM
08/07/16 02:30 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Cam bearings are MUCH easier to install when the crank/rods/pistons are out of the block. Unless you're tearing the whole thing down or the bearings are bad, I would leave them alone.Yep, you will need new push rods.Mock it all up,measure and have a good company make you some up, I used Smith Bros.Good luck on your upgrade!
Re: upgrading cam to a solid lifter [Re: moparpro] #2131819
08/13/16 10:21 AM
08/13/16 10:21 AM
Wisconsin
Medlock51 Offline
Medlock51  Offline
Wisconsin
No need to change the cam bearings. Take a close look at the timing chain and replace it if it has any excess slack. Inspect the gear on the idler shaft. You'll also need an adjustable valve train...
