Page 3 of 7 1 2 3 4 5 6 7
Re: Organosol "The Bulletin" January 15, 1969 [Re: A12] #21254
10/19/07 09:50 AM
10/19/07 09:50 AM
Buckle of corn belt ,c. lll.
420SIX Offline
420SIX  Offline
Frank says their formula is made from the last of the original PPG stuff..The 9355 formula is going to be wrong.......
Re: Organosol "The Bulletin" January 15, 1969 [Re: 420SIX] #21255
10/19/07 11:33 AM
10/19/07 11:33 AM
Not an A12 owner guys but my Roadrunner does have the black out hood treatment. Is this the same paint? Thanks guys.
Re: Organosol "The Bulletin" January 15, 1969 [Re: 420SIX] #21256
10/19/07 01:02 PM
10/19/07 01:02 PM
Zzyzx Road
beepbeep Offline
moparts member
beepbeep  Offline
moparts member
Zzyzx Road
Unless something has changed very recently RG's organosol was urathane not lacquar.
Amazing how an unchallenged lie can become the absolute truth.
Re: Organosol "The Bulletin" January 15, 1969 [Re: beepbeep] #21257
10/19/07 02:33 PM
10/19/07 02:33 PM
420SIX Offline
420SIX  Offline
It is acrylic lacquer
Re: Organosol "The Bulletin" January 15, 1969 [Re: 420SIX] #21258
10/19/07 11:06 PM
10/19/07 11:06 PM
California
sixpaktoogo Offline
sixpaktoogo  Offline
California
Just bought some from him a few months ago. Doesn't say in his catalog that it's lacquer, and most of his other specialty paints are enamel! I called and asked Frank what I'm supposed to do with it since my car is painted in urethane enamel. He told me that it's my painter's problem!! What a tool!
Re: Organosol "The Bulletin" January 15, 1969 [Re: 420SIX] #21259
10/20/07 01:16 PM
10/20/07 01:16 PM
This should not matter, since lacuer was used over enamel originaly without any catylization like is used today.
simply try a test spray to make sure it does not lift on a scrap piece of metal. Your painter "should" know if he can do this or not. (I have only used it over enamel).
Now to the texture of hood blackout.
1). 9423 IS NOT IT.
2). For comparison of an original fine texture which i think is being referred to? look at original untouched dash and steering column paint, you will see that it is not the same as deck trim panel paint 9355, and is comparable to the hood black out texture.
3). Could it be that there was another paint vendor that supplied product to chrysler?
YES, Now which one was it?
Since that mfg no longer has laquers (you will have to find a very old mixing bench and formulas), it is going to require more use of ones resourses to come up with the comparison paint.
Mike
I have LOTS experinece with OE textured paints.
Re: Organosol "The Bulletin" January 15, 1969 #21260
10/21/07 12:51 PM
10/21/07 12:51 PM
California
sixpaktoogo Offline
sixpaktoogo  Offline
California
Lacquer was able to be applied over factory paint because it was baked enamel, not fresh urethane. Even if it doesn't lift on a test panel, I would NEVER take a chance on spraying lacquer over a freshly enameled car, catylized or not!
Re: Organosol "The Bulletin" January 15, 1969 [Re: sixpaktoogo] #21261
10/21/07 02:04 PM
10/21/07 02:04 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: Organosol "The Bulletin" January 15, 1969 [Re: Alaskan_TA] #21262
10/21/07 02:15 PM
10/21/07 02:15 PM
420SIX Offline
420SIX  Offline
Has anyone used the ppg enamel fromula, and compared to a known original A-12 ?
Re: Organosol "The Bulletin" January 15, 1969 [Re: 420SIX] #21263
01/29/08 03:32 PM
01/29/08 03:32 PM
I have used both the PPG Duracryl Organosol and the PPG DCC urethane Organosol.I also have several examples of original Organosol on my original paint 69 Road Runner fender and 69 Charger tailpanel,as well as other original paint Organosol finishes I have studied.Here's what I found:
PPG Organosol mixed in DCC urethane is very close.Nice semi smooth finish and semi flat black finish.Closely matches original Chrysler finish which is actually metallic flat black.
PPG organosol mixed in Duracryl lacquer produces a gritty finish more like dash panels etc.While it is a cool finish,it is not correct in my opinion.I have seen original AAR cudas,A12 cars and V21 Road Runners,Chargers and 71 Dusters etc,and they never had the gritty finish like we see on the show cars nowdays.
Yes the textured organosol looks cool-but it does not look correct to me.
Re: Organosol "The Bulletin" January 15, 1969 #21264
01/29/08 05:10 PM
01/29/08 05:10 PM
Wendy, I'm home.
dstryr Offline
dstryr  Offline
Wendy, I'm home.
The original paint on my A12 Roadrunner hood matches your description to a 'T'. Thanks for the comparison.
dstryr, since 1986.
Re: Organosol "The Bulletin" January 15, 1969 #21265
01/30/08 06:01 PM
01/30/08 06:01 PM
VA
RapidRunner Offline
RapidRunner  Offline
VA
Who knows? The Shadow Knows! But he ain't on this fraking forum! "This restoration is a test,, It is ONLY a test, Had this been an actual Restoration I would have received instructions on what to do and where to get the MONEY!" -------------------------------
Re: Organosol "The Bulletin" January 15, 1969 [Re: A12] #21266
01/30/08 09:30 PM
01/30/08 09:30 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
Another FYI
my birthday in mopar history - yeh baby
Re: Organosol "The Bulletin" January 15, 1969 [Re: A12] #21267
08/29/08 04:11 PM
08/29/08 04:11 PM
Rutherfordton NC
BarryBum Offline
Fruit Of The Loon
BarryBum  Offline
Fruit Of The Loon
Rutherfordton NC
bump for my records
Re: Organosol "The Bulletin" January 15, 1969 [Re: BarryBum] #21268
11/30/08 04:13 PM
11/30/08 04:13 PM
New Brunswick, Canada
TrxR Offline
TrxR  Offline
So the if I read this right the DCC9355 urethane is going to be the closest match to the factory hoods? Also does this go chaulky? Is it a single stage or does it require a clear?
Re: Organosol "The Bulletin" January 15, 1969 [Re: TrxR] #21269
11/30/08 04:20 PM
11/30/08 04:20 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
DCC is PPG Concept single stage. It doesnt use a clear and should hold up much better then Lacquer. I have never used it so I cant comment on how it looks.
Re: Organosol "The Bulletin" January 15, 1969 [Re: A12] #21270
11/30/08 05:02 PM
11/30/08 05:02 PM
west kentucky
gomangoRTSE Offline
gomangoRTSE  Offline
west kentucky
This is a lil off the subject matter, but whats the correct organsol formula for the tail panels on the 1970 RT/SE cars?? I thought it had some gray in it, or am I mistaken?? Thanks
Re: Organosol "The Bulletin" January 15, 1969 [Re: JeffsCustomPaint] #21271
11/30/08 08:56 PM
11/30/08 08:56 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
All you restoration experts please note:
dcc9355 has no texture in it. None, nadda, Zip
ddl 9355 does have the texture additive but the new texture material is not the same as the orig paint.
I will be spraying a hood soon with the orig [nos] ddl9355 formula and I will post my results.
Re: Organosol "The Bulletin" January 15, 1969 [Re: sixpaktoogo] #21272
11/30/08 09:54 PM
11/30/08 09:54 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
No surprise there!.....last time I dealt with Frank, didn't have a clue what Vari-prime, or etch-primer was? ....wanted a "paint school" lesson over the phone,......won't even go into the "incorrect" parts he knowingly wanted and purchased for a customers "correct", big $$$$$$$ restoration
Re: Organosol "The Bulletin" January 15, 1969 [Re: DAYCLONA] #21273
07/22/09 04:06 PM
07/22/09 04:06 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Just bumping this up to see if anyone has anything new to add on this subject since I will need to advise my paint guy.
Thanks, Joe
